Sony 42inch TV flickering
  • reddemonic
    • Jun 2015
    • 42
    i've uploaded a video to show you guys. screen is not damaged. oneday just start doing this.
    panel turning bad or is it the board inside?
    thanks guys
    https://www.youtube.com/watch?v=gh9Tujzs1es
  • Diah
    • Feb 2013
    • 6363
    Re: Sony 42inch TV flickering
    which model yours Sony is ?
    can you put it in stand by mode with RC?
    • reddemonic
      • Jun 2015
      • 42
      model is 42W654A, i'll go try now.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I have seen a failed Mb in this model before never fixed it but guessing bga solder issue as the main cpu ran hot. Lets see what others think.
        • reddemonic
          • Jun 2015
          • 42
          yes standby is working.
          • Diah
            • Feb 2013
            • 6363
            its much bad connection / soldering..take all boards apart one by one cleaning them and rebuilt again, give attention to sockets pins soldering if one pin had crack..
            • reddemonic
              • Jun 2015
              • 42
              is this the board that is causing the problem? can i buy this ?
              https://spares2repair.co.uk/sony-kdl...7284a008157eeb
              so the panel is still good right?
              cheers Diah and ReeceyBurger123
              • Diah
                • Feb 2013
                • 6363
                yors panel OK. but don't buy this boards.. LOL its AV boards... do what i told you first for cleaning and inspection.
                • reddemonic
                  • Jun 2015
                  • 42
                  ok, i'll do it this weekend. i'll report back then. thanks again
                  • reddemonic
                    • Jun 2015
                    • 42
                    hello all, i am back.
                    where is the tcon board located on this TV? is it under the top black cover?
                    • reddemonic
                      • Jun 2015
                      • 42
                      i think theres no tcon board in this model. so problem has to be the main board?
                      so i guess replace with another main board which is this one:
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        For that I think is the lvds cable......the black cable connected to the screen the socket were it goes connected it might need some soder at the side connection......try this before anything. Push a bit of pressure on the main cpu on the main board first take out the metal plate post pictures
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          I wonder if it's suffering from damage due to wiping the screen with a wet cloth. It may be worth doing a quick visual check of the long circuit board with the integrated tcon which connects to the lcd panel for signs of moisture/water damage.
                          • cliff_hootarski
                            • Jul 2006
                            • 411
                            Sony.....I'm betting bad tab bonds.
                            • reddemonic
                              • Jun 2015
                              • 42
                              nothing work. na i've tried putting pressure on all flex cables, tab bonds. etc.
                              i think it could this module
                              not my picture.
                              the tab bonds are soldered there so i wont able to replace it.
                              • reddemonic
                                • Jun 2015
                                • 42
                                what are the chance is the main av board cuasing the problem? theres a cpu in there. maybe cpu gone bad like a gpu on a laptop?
                                should i order a new main av board?
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                • LINCKODE
                                  Sony Bravia KDL-37S5600 inverted color and flickering
                                  by LINCKODE
                                  Hello!
                                  I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
                                  - Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
                                  - Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
                                  - Bad image detail/sharpness
                                  These issues switch between each other from time to time.
                                  After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am...
                                  12-14-2022, 08:34 AM
                                • reessi
                                  ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                  by reessi
                                  The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                  They are black on the right and gradually fade to nothing on the far left.
                                  They start either after 5 mins or up to 2 hours after so annoying for testing.
                                  They flicker continuously very fast! With a slight pause milli-second every second.
                                  Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                  I tested each half by removing the first the left flex from...
                                  06-03-2025, 09:58 AM
                                • storexxm
                                  Sony 65AG9 Oled Flickering
                                  by storexxm
                                  https://youtu.be/lIy3wANcWKA
                                  Does anyone have an idea what can cause this "flickering" i ve never seen something like this before on an oled TV
                                  Hope someone can help me :-)
                                  08-16-2023, 08:55 AM
                                • dkneyle
                                  Sony KDL-46HX850 Can't upgrade/update firmware
                                  by dkneyle
                                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                  09-25-2024, 10:44 PM
