LG 60PK950-UA Plasma no picture or sound
  • Izzy16
    • Aug 2016
    I am looking for some troubleshooting help on a 6 year old LG 60pk950 television.
    The symptom it the normal red standby light is on and when the power is turned on the normal white light comes on and then the relays click, all as it had done before the problem.
    The sound never pops or does anything, the screen is a very faint solid black and when I try the TV menu nothing is displayed.
    I started out by inspecting the electrolytic capacitors and found nothing.
    Watched a few videos that helped to explain the function of the different boards, I then checked all the power on the Main Power board (VS, VA, M5V, 17v, STDBY...) all were well within what was printed on the board.
    Then I found this post on your wonderful forum - https://www.badcaps.net/forum/showthread.php?t=33454
    It has logical troubleshooting and well written explanations, this led to post #13 where tom66 shows a picture of how to get the test pattern on the screen.
    Unlike the original poster I was able to get the test pattern to show all the colors and patterns.
    These leads to my question, since the Main Logic board EBR63450301 with connector P31 removed and the jumper installed provides a test pattern shows me that the X, Y and Power boards are all functioning.
    Only the Main Logic board EBR63450301 and the Main board (Connectors) EBR68027906 are left to verify which one might be the problem as the sender or the receiver could be the cause.
    If someone has any additional steps to help me prove this further it would be greatly appreciated, also a link to a Service Manual would be nice.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 60PK950-UA Plasma no picture or sound
    With the rear cover removed....Post clear pics of the backside of the TV so we can see how the boards are interconnected.
    • Izzy16
      • Aug 2016
      Hello Andrew,
      Please see this post,
      it has a great set of pictures that are the same as my LG.
      • cliff_hootarski
        • Jul 2006
        • 411
        If the TV displays the color test patterns properly, you have verified all the boards except the mainboard work. Start looking for a replacement.(mainboard)
        Go to Shopjimmy.com with your TV model # and you will see several different mainboards. Watch their tutorial video to determine the correct model # of
        mainboard to look for.
        • mmartell
          • Oct 2013
          • 3189
          Excellent post and good advice.
          • Izzy16
            • Aug 2016
            My LG is fixed, because of the great help of the forum the Main Board was the fix.
            It was a bit hard to find someone that had it in stock but shopjimmy showed alternate part numbers and I was able to find EBT61261904 from Sears Part Direct and if needed they have a nice picture and list of more parts, it cost about $200.
            • sh3wq
              • Jun 2018
              I found this post while trying to diagnose the problem of my LG 60PK750-UA, which has the same logic board (EBR63450301), and has main board EAX61557904.
              Have to say that the picture posted by tom66 showing where the testing points are is really helpful! I got testing patterns on the display too. I have found repair services for this main board, and now since my main board seems to be the problem, I will give it a try.
              • KYBOSH
                Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                by KYBOSH
                Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                No picture but you hear the TV static (white noise) playing loud and clear.
                The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                But it seems they didn't get too far and just left it.
                When I first took a look I was amazed at how pristine the inside looked.
                Its as if the TV had been in a time capsule.
                Caps looked like they were just pulled off the self.
                Copper coils had no sign of corrosion on...
                02-01-2023, 11:10 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
