I am looking for some help troubleshooting an LG 60pk950-UA plasma television. When I took the back cover off I also found this number PDP60R10000. TV powers up but no picture or sound. We didn't use the tv for almost a year and when I went to turn it on yesterday it powered on but no sound or picture. In the past it acted up a couple times(had sound and no picture or picture and no sound, cant remember which one it was) I assumed it was the LG wireless media box. If you power cycled the tv then it would work. Now I have no sound or picture. Any help would be greatly appreciated. I have attached pictures of the boards.
LG Plasma 60pk950-UA no picture or sound
Tags: None
Re: LG Plasma 60pk950-UA no picture or sound
I was just looking at the photos and in the 3rd picture I see a few bent caps on the primary circuit. I'm no pro, but isn't that a sign of a bad cap? I just figured I'd say something cause I want to know if they are (possibly) bad.
I'll wait for a veteran to speak up. I just wanted to point and ask...Comment
Well good luck! That's all I'm good for!Comment
OK, on this circuit board, there is a light (logic board)
https://www.badcaps.net/forum/attach...4&d=1386049781
Do you see the light glow or flash when the set is powered up?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Do you see the light glow or flash when the set is powered up?Comment
OK, at this point, you'll need a digital multimeter. Do you have one, or can you borrow one? An analog multimeter will not suffice unfortunately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, the top right connector on this board has two pins at the bottom marked VS
https://www.badcaps.net/forum/attach...2&d=1386049781
With the red probe of the meter touching VS, black probe on chassis and meter on highest DC range (or autoranging) measure the voltage on the bottom most pin with the set in the fault condition. What do you see?
The ratings for Vs, Va and other voltages are printed on the Panel Sticker which has LG Electronics logo and PDP60####### markings.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
ok, the top right connector on this board has two pins at the bottom marked vs
with the red probe of the meter touching vs, black probe on chassis and meter on highest dc range (or autoranging) measure the voltage on the bottom most pin with the set in the fault condition. What do you see?
The ratings for vs, va and other voltages are printed on the panel sticker which has lg electronics logo and pdp60####### markings.Comment
OK, that's good.
See attachment.
With TV OFF and UNPLUGGED:
- Disconnect the blue highlighted cable, by pressing each clip gently and pulling backwards with minimal force.
- Place a wire link between the two holes marked in red.
Then plug TV in and turn on if it is in standby.
You may or may not see test patterns, but if you do, it indicates the main board is bad (not this board... the board with HDMI etc.)Last edited by tom66; 12-03-2013, 09:05 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, that's good.
See attachment.
You may or may not see test patterns, but if you do, it indicates the main board is bad (not this board... the board with HDMI etc.)Comment
Luktech is probably not correct. It is most likely not involving the main board at the moment. More testing is necessary.
At this point, I am going to assume you have a PDP60R1 panel, but please confirm this by looking at the sticker with voltages on it, it will be marked something like "LG Electronics PDP60R1##### Made in KOREA 2010.09.03".
Please refer here:
http://tgohome.com/ServiceManuals/?d...h=Submit+Query
On the 5th page it instructs you on how to test the Vsc and -Vy voltages. Please do so and compare to the label on the plasma panel.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, that's good.
See attachment.
VS=201.6
VA=59.6V
M5V=5.15V
17V=17.17V
STBY=5.15V
F801
stby 0v
run 174.7v
F501
stby 0v
run 174.7v
F301
stby73.8v
run 174.3vComment
For now, since the Vs and other voltages are present, the power board is not currently suspect. Please check the -Vy and Vsc first.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by KYBOSHPicked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
No picture but you hear the TV static (white noise) playing loud and clear.
The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
But it seems they didn't get too far and just left it.
When I first took a look I was amazed at how pristine the inside looked.
Its as if the TV had been in a time capsule.
Caps looked like they were just pulled off the self.
Copper coils had no sign of corrosion on... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... - Loading...
- No more items.
