Please Help! LG 60PZ950 plasma doesn't have any picture nor sound when turn on.
  • SORGAW
    • Aug 2016
    • 5
    As title.
    The power indicator did change from red to blue, and the panel does have a slight glow to it.
    Thank you so much! I can't afford another TV now.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Please Help! LG 60PZ950 plasma doesn't have any picture nor sound when turn on.
    Read some of the previous threads on the set using the search bar saves us retyping whole threads again
    • SORGAW
      • Aug 2016
      • 5
      Hi, search on 60pz950 only found other discolor problem, not the no picture/sound problem that I have.
      Tom66's general plasma thread suggested to test without the z-sus first, so should I disconnect both connectors I circle in red? Much thanks!!
      Quote from tom66's plasma guide : https://www.badcaps.net/forum/showthread.php?t=18542&
      "No picture. Big one, lots of causes, lots of problems. First, check if you have sound when you plug in a source. If so, it's probably not a power supply fault. Does the set respond to the remote control or side buttons? Is it stuck in standby? There are too many power supply faults here to debug - create a thread.
      However, if it doesn't seem like a power supply fault - if you have sound and the TV will respond normally - then it's likely a Y-sustain or Z-sustain fault.
      If you don't have sound: First, turn the TV off and unplug it from the wall. Give it 5 minutes to discharge the capacitors. Then, unplug the connector going to the Z-sustain.Now plug it in, do you have sound? If so, the Z-sustain is failed. Now, give it another 5 minutes and then disconnect the Y-sustain and re-connect the Z-sustain. If it now powers up with sound, then the Y-sustain is faulty. With a Y-sustain problem, it can also be a buffer problem. If your TV has two buffers (upper and lower), disconnect the upper buffer (wait 5 minutes before doing so), and see if you get a picture on the lower of the screen, then swap around. The board that when removed gives a picture is faulty. If your TV has only one buffer, remove that and see if it comes on with sound.
      If you have sound: This is often a Y-sustain fault. There is usually at least one fuse on the Y-sustain. First, unplug the TV and give it 5 minutes to discharge the capacitors. Then, set your DMM to the 200 ohm range. Touch the red and black together. Note the reading, it should be around 0-2 ohms. Now, touch one probe on one end of the fuse, and the other probe on the other end. If your DMM reads "1" on the left hand side, or "OL", the fuse is blown. If you get the same value as when you touched the probes together, the fuse is not blown.
      You should replace the fuse. Should that then blow again, you need to repair or replace the Y-sustain. Diagnosing a particular fault is tricky and requires considerable experience. Unless the Y-sustain is very expensive, or difficult to repair, I would advise a simple swap of the board."
      • SORGAW
        • Aug 2016
        • 5
        bump
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ok right as the panel does light up/prime, this means the sustain boards are working for now but there is no information being written to the panel meaning now image.
          Do you know how to run the test patterns for Lg Plasmas if not I will instruct you ? Also I would advise for this model after repair you resolder the coils on the Zsus help prevent future issues.
          • SORGAW
            • Aug 2016
            • 5
            sorry, dont know how to run test pattern, please advise.
            I did check the solder on the back of the z-sus, they seem good. but you are right, it's good to resolder them to prevent future issues
            • endot800
              • Apr 2017
              • 7
              I'm having the same issue with no pic or sound. TV powers on with the blue light on front, blinks when pressing remote so it's getting a signal. I disconnected first the Y-Sus board. No sound or pic. Then the Z-sus, same result. I tried the 2 buffer boards, first the upper. Half of horizontal screen was light gray color. Same thing happened with the lower disconnected. The one thing I found out of place but not sure about is on the upper right corner of the Main Board looks like soldering flux or melted parts? Here some pics I took along with a New Main Board pic. I do not have MM so I cannot check the values.
              • endot800
                • Apr 2017
                • 7
                Here are the pics
                • endot800
                  • Apr 2017
                  • 7
                  Forgot the new board pic.
                  • endot800
                    • Apr 2017
                    • 7
                    I managed to get some pics of the back of the Z-Board. The three coils are what this is. Looks like some cracks in the solder. The one thing that I can't figure out is how remove the board itself from the three connector clips. I can't seem to disconnect it from the thin board so I tried removing that one as well but I can't figure out how to remove the ribbon cables. I release the latch and they are loose, but they wont slide out. If anyone knows how to do it please advise.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      Gently squeeze both sides of connector and pull out. It will move about 1/8 of an inch. Then take something, like a guitar pick, and push the ribbon down and wiggle it out. There are two "fangs" that hold the ribbon cable in.
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        resolder coils on y-sustain board as well.
                        Proud owner of dozens of broken TV's and many,many,many boards.
                        Our website and passion:http://hollenhundshepherds.com/
                        • endot800
                          • Apr 2017
                          • 7
                          Does anyone know how to remove the Z-Sus board from these connectors. I just can't figure it out?
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            I use a 4" jack knife. Start at the top, then go to the bottom, and keep working at it. It will come apart. There are some heat sink pads under the board that seem to make it stuck, but it will come loose.
                            • endot800
                              • Apr 2017
                              • 7
                              Turns out that the Mainboard was bad. I was able to get another in the set it fired right back on. Hopefully this set will last me a bit longer before moving on to OLED as prices continue to fall.
                              • endot800
                                • Apr 2017
                                • 7
                                It seems my enjoyment was short lived. I now have sound, but no picture. I suspect a faulty Y-Sus board. Going to see if I can have it repaired or opt for a new set.
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Did you check the coil solder connections on the Z and Y board?
                                  • KYBOSH
                                    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                    by KYBOSH
                                    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                    No picture but you hear the TV static (white noise) playing loud and clear.
                                    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                    But it seems they didn't get too far and just left it.
                                    When I first took a look I was amazed at how pristine the inside looked.
                                    Its as if the TV had been in a time capsule.
                                    Caps looked like they were just pulled off the self.
                                    Copper coils had no sign of corrosion on...
                                    02-01-2023, 11:10 PM
                                  • TR103
                                    by TR103
                                    - it keeps rebooting
                                    01-22-2025, 04:12 PM
                                  • Mgiffune
                                    by Mgiffune
                                    I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                                    I ordered a supposedly β€˜new' Tcon board this time, and
                                    06-09-2024, 10:28 AM
                                  • Ierwin
                                    by Ierwin
                                    05-13-2025, 03:31 PM
                                  • jchang
                                    Samsung UN70NU6900F no picture and no sound
                                    by jchang
                                    Hi all
                                    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                    Symptom:
                                    No picture no sound.
                                    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                    No sound at all.
                                    What I tried:
                                    1. I tried unplugging the left or right ribbon...
                                    01-09-2023, 06:28 PM
