Hi guys
Well i have a 42s10 that has a 6 blink problem.
I got the set and from inside it looks horrible, full of dust, smoke from cigarettes, just a lot of thermal stress from what i can tell just looking it inside.
So the problem is that nothing is shorted on SC and i have 6 blinks. Culprit is MID voltage that raises up to 50-55V and that's what triggers the error, i assume.
Other voltages are up to spec, it's only this one that is making problems. I have a working TNPA4844 which i fixed few days that also had almost the same problem with MID voltage which was raising up to 155V. Fixed that with changing IC521 which was leaky on pin 7, and Q441 and Q452, also leaky.
So i am comparing this working TNPA4844 with this TNPA4829 and can't find any difference in measurements.
I may change the driver but readings are the same.
Any thoughts what can cause problems with MID voltage?
