I started this subreddit because I found out many TV's can be easily repaired, and w
  • ElecNewb
    • Feb 2015
    • 6
    • Mexico
    Please delete this as it was a mistake :/ Sorry
  • chronic519
    Mats / mods: detected and repaired GPU fault. Cant seem to test after!
    by chronic519
    Hello.
    GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
    Found issue with a RAM block
    Replaced, green lines gone.
    Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
    Used a good card to test and same results low errors 32+.
    I am just search for some form of command to do a full test on the GPU.
    I just ran the mats command with my good GPU and passed after roughly 40 min.
    The repaired one, ran...
    05-20-2025, 07:56 PM
  • phuzzyday
    Sony KD-70X690E. Started with reset loops.. then it got more complicated. I'm at wits end!
    by phuzzyday
    First of all, thank you everyone who helps others in here! You guys are treasures! Please bear with me, this may be long. I have tried a LOT.
    First, my wife said the TV was turning off and on. When cold it would be fine for several minutes, then it would start resetting.
    I opened it up and noted there are two main lines coming out of the supply besides the backlight., The T-Con 12V line and the main 12V line.
    TRIED 1 - I scoped power coming from Power Supply while it was all still connected. I noted that just before it reset, the 12V line going to the T-Con was going...
    03-26-2025, 05:53 PM
  • waigy
    Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
    by waigy
    As the title.
    I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
    It looks basic enough inside with large components so I could do a full recap pretty easily.
    Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
    If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
    I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
    11-08-2024, 03:53 AM
  • kamkooltech
    by kamkooltech
    Wow, that amazing story.
    that is journey of life, to be come an active person, person have to work hard to get a peaceful life.
    That remind me my passes when I started repairing laptop too, I don't have idea but I put my full focus and attention to get it right, I got my repaired kits and I stated processing the board, I stated guesting if these or that chip bad, I only gest right if the chip burnt or heating, if I couldn't able to repaired I gave the pro to help me repaired it and pay them, so before I couple the board I will take a look what and what they touch and what they change...
    12-18-2023, 12:46 AM
  • huzo
    Lenovo ideapad 1 not recognizing NVME
    by huzo
    Model is ideapad 1 15amn7 ,the board is 5B21J30218 HLS1C_HLS1D LA-L502P with ryzen 5 7th gen... The laptop came to me for broken hinges and displaying only the backlight on the screen...i repaired the hinges and tried booting and all i got was backlight on the screen,but caps lock worked, so i figured the screen or the flat cable was bad, i had the same laptop and connected the cable and screen from the other and the screen acted same, and original lcd works on the other laptop...so then i started removing wifi card and nvme and it started showing picture and i figured out the nvme was blocking...
    09-04-2025, 01:08 AM
