Insignia ns-lcd32
  • fixerupper75
    • Oct 2014
    • 125
    • us
    Insignia ns-lcd32
    Hello all,
    I got this NS-lcd32 with no standby light. when i press the power button the standby light turns green. It will not turn off i have to unplug it. Will post asap. these are reading from the mainboard.
    5v=0
    gnd=0
    5v=5vdc
    gnd=0
    12v=0
    12v=0
    gnd
    gnd
    3.3=3.1vdc
    gnd
    stby=3.1
  • CapLeaker
    Leaking Member
    • 8327
    Re: Insignia ns-lcd32
    we need straight shot, high resolution pictures of your boards.
    • fixerupper75
      • Oct 2014
      • 125
      • us
      try these if this doesn't work ill try again tomorrow.
      • CapLeaker
        Leaking Member
        • 8327
        Those are far from hi resolution and those aren't your boards. If you can't see it on your screen, I can't see either on mine. We need to be able to see and read details.
        • fixerupper75
          • Oct 2014
          • 125
          • us
          Here are some pictures. thanks for any help!!!
          • CapLeaker
            Leaking Member
            • 8327
            Looks like your main board is sending PSon, but the PSU isn't turning on.
            • fixerupper75
              • Oct 2014
              • 125
              • us
              So where sHould I start troubleshooting
              • CapLeaker
                Leaking Member
                • 8327
                Here is a service manual for it.
                Disconnect everything from the PSU and force it on by jumping STBY voltage to PSon with a 1k resistor. Plug it in and check all the output rails.
                • CapLeaker
                  Leaking Member
                  • 8327
                  Be careful in the primary section on the power supply. When the PSU is working correctly you got around 400V DC on the main filter cap.
                  • tbsmith
                    Insignia NS-50F301NA24 No standby power, no +Va, Vm, +Vl etc.
                    by tbsmith
                    There is voltage on the bridge rectifier and main caps (163V). Fuses all check good. One of the smaller electrolytic caps (C9112 which is 50V, 100uF) looked bloated, it measured 60uF with one tester, and defective with another. I replaced it temporarily with same uF rating, higher voltage since I don't have the exact one. I also found that one of the switching mosfets (for lower voltage DC supply I think) was shorted. It is a 50R800CE which I didn't have, but had something with the same voltage and current rating and a similar Rds. None of these fixes helped. I'm out of ideas. Any suggestions...
                    08-11-2025, 06:15 PM
                  • valvashon
                    Insignia NS-LCD19-09 no standby LED; (new problem)
                    by valvashon
                    Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
                    Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
                    Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
                    08-30-2023, 10:41 AM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
