TV Led lg 32ln575 - no backlight
  • Ad-M
    • Jul 2016
    • 10
    • Poland
    TV is LG LED 32ln575
    Power supply: EAX64905001(2.6)
    There is sound, everything is working, just no backlight.
    Led+ give no voltage (1v or less)(doesn't matter if connected or not). I just have no idea why. I tried many things for last few days... Today I changed power supply to EAX64905001(2.4) (from different TV) and still no backlight (no voltage on LED+ connector).
    I measured voltage for Connectors to the Mother Board: (stand by)
    0(GND) 0(GND)
    0 (12v) 0 (n.c.)
    0 (12v) 0 (12v)
    0 (GND) 0 (GND)
    0 (24v) 0 (24v)
    0 (GND) 0 (GND)
    3.37v (3.5v) 0 (n.c.)
    3.37v (3.5v) 0 (PDIM)
    0 (PWR-ON) 0 (DRV-ON)
    (Power ON)
    0(GND) 0 (GND)
    12v (12v) 23,7v (n.c.)
    12v (12v) 12v (12v)
    0 (GND) 0 (GND)
    23.7 (24v) 23,7v (24v)
    0 (GND) 0 (GND)
    3.43v (3.5v) 0 (n.c.)
    3.43v (3.5v) 1,1v (PDIM)
    3.29v (PWR-ON) 3.0v (DRV-ON)
    Nothing seems off to me.
    I would be grateful for any advice.
    Re: TV Led lg 32ln575 - no backlight
    So the replacement power supply board is a known good working board for sure?
    You do have all the correct controls signals from the main board.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Suspect an led problem. Shine a very bright light on the screen and look very carefully to see if you can make the picture out. Select menu on remote.
        You may want to read this thread:
        https://www.badcaps.net/forum/showthread.php?p=650876
        • CapLeaker
          Leaking Member
          • 8132
          It's not an LED problem. I rather think there is a problem with the driver on that board.
          budm beat me to it.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            I just followed Budm's link and it looks to be an identical problem with the driver chip.
            I think the hint I should have picked up on was no LED voltage whether plugged in or not.
              Yes, it is the same board, the PCBA P/N is LG EAY62810301, the EAX???? is the blank PCB #.
              Always match the board with the PCBA number since blank PCB can be stuffed in many ways to make many PCBAs for many models of TVs.
              • Ad-M
                • Jul 2016
                • 10
                • Poland
                @Yes, there is picture if i use flashlight.
                @I read this thread earlier, on VCC i have 12v.
                If I disconnection LEDs, then shouldn't there be some voltage if LEDs are broken?
                @I cant be 100% sure about this second power supply, is from TV with broken screen and for now I can't check it in any other way than connecting to this TV.
                This is PCBA number?: LGIT PCB P/N:3PCR00274B
                edit: i added .pdf file. On page 19 is power supply schematic.
                • Dcole73
                  • 4
                  • Nigeria
                  Hello Ad-M.
                  Were you able to resolve this issue?
                  Here's some info that may help.
                  I think one or two of the LEDs in your tv are bad.
                  Since they are connected in series, if one is bad, others won't work. You have to open it up and test each LED to find the faulty one.
                  The bad LED needs to be replaced. It is usually easier to replace the strip containing the bad LEDs .
                  NOTE: The voltage for the back lights is 195V DC. So ensure it is disconnected from the power board before working on the LEDs.
                  • cevar_blackwing
                    A1466 (820-00165) No Chime, No POST
                    by cevar_blackwing
                    Good Day!
                    History:
                    The board was not booting, upon opening it the fan was spinning but there is no PPVCC_S0_CPU. PP1V05_S0 was 0.550v. PP1V05_S0 Diode Mode = 0.007v , Resistance = 3.4ohm. ALL_SYS_PWRGD = 3.340v. I suspected it was a short on the PP1V05_S0, so I lifted L7630 and found the 3.4ohm short on the Load Side. I injected 1v on the rail and it was only taking 34mA. After this I returned L7630 and investigated the U7600 (TPS51916). It has VREF (1.8v) and REFIN pins. And sure enough, the REFIN voltage is just 0.550v. That is why there is ALL_SYS_PWRGD, because it thinks...
                    11-04-2020, 01:48 PM
                  • tahc81
                    Lenovo Yoga 370 LA-E292P no power on VCCCPUCORE, VCCGFXCORE_I, VCCSA
                    by tahc81
                    Hi everyone, having LA-E292P on a desk, there was some light corrosion around PU137 (NCP81218) - cleaned with fiberglass pen + ispropyl alcohol. All basic rails are ok (3.3, 5, 1.2, 12 , charging ok), except the VCCCPUCORE, VCCGFXCORE_I, VCCSA. All these are driven by NCP81218 + 3x NCP81382, HIGH state on CPUCORE_ON, but LOW on DRVON which enabled those 3 NCP81382. Tried to connect 3.3V from CPUCORE_ON to DRVON, but measured LOW after this. Resistance between those rails and GND are 6 / 9 / 19 ohms. Any suggestion what else to check. Thanks
                    04-09-2024, 03:39 AM
                  • jimmyboy111
                    Repair Log - TCL ROKU 65S4 BACKLIGHT DEAD
                    by jimmyboy111
                    Hopefully I can save someone some time or maybe they can avoid fixing these garbage epoxied TV sets
                    .. stripping down was a pain .. tons of screws all along bezel edge .. the top of the glass LCD panel is glued to the casing (for a reason)
                    .. all in all took around 4-6 hours to repair teardown .. swap .. reassemble .. current adjustment and then burn in and extra evening
                    .. single blown backlight led top left row .. 3030 5.5v (6v) .. I had some in stock from another set
                    .. swapping LED no problem .. one bad led .. the solder pad under this LED is normal .. no...
                    02-01-2022, 11:33 PM
                  • questore
                    HP 250 G6 LA-E801P Please help identify IC.
                    by questore
                    Hello Everyone,
                    I have a laptop that has a faulty IC, the boardview and schematic cannot help to identify it.
                    Board has 3 identical IC on it named my boardview: PUG1, PUA1, PUZ2.
                    Shematics are not helpfull cause they give the ic as RT9610CGQW_WDFN8 and that is not correct. (pin 3 should be DRVON and it is not by datasheet)
                    its a 8 pin IC and has marking of "CGJ" on it.
                    Can you help me what it could be?...
                    04-29-2025, 05:18 AM
                  • multitech
                    Dell G7 7588 LA-E994P missing +VCC_CORE
                    by multitech
                    Hi everyone, i got a Dell G7 7588 missing +VCC_CORE and +VCCGT, i have already checked the power on sequency, everything seens to be fine, i also have PCH_PLTRST# signal present.
                    the laptop turns on but no video.
                    i flashed a new BIOS and also Clean ME, same issue.
                    i already replaced PU5000 NCP81215D
                    DRVON 4.75v
                    VR_RDY 3.3v
                    EN 3.3v
                    +VCCSA 1.04v
                    +VCC_CORE resistance is 4ohm.
                    no GPU power also but if i remove the +VCCSA coil i have the GPU powered and the VRAMs.
                    Thank you.
                    01-31-2025, 10:32 AM
