What type of multimeter are you using?
  • johns1mj
    • May 2015
    • 242
    Don't know if this is ok to post here. What type of multimeter are you using to test igbt and mosfet? I am using a klein mm200 but I do not think it is able to do what I need. It only has an average .6 mv for testing in diode mode.
    What do you recommend?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: What type of multimeter are you using?
    The Klein MM200 manual says diode test mode outputs a test current of 0.6mA and approximately 1.5V DC or less (probably depending on the battery condition).
    If you are looking for a shorted igbt or mosfet, a reading of 0.00 or close to 0.00 tells you it is shorted.
    What is your Klein not doing? Or put another way, what problems are you having? Be specific.
    --- begin sig file ---
    --- end sig file ---
    • culcuhain
      • May 2016
      • 186
      • U$@
      For transistors, inducers, caps, mosfetshttps://www.amazon.com/gp/aw/d/B00NKY3M1W/ref=mp_s_a_1_1?ie=UTF8&qid=1469493576&sr=8-1&pi=SL75_QL70&keywords=transistor+tester
      Dont laugh. It works great.
      • retiredcaps
        • Apr 2010
        • 9271
        https://www.amazon.com/gp/aw/d/B00NK...nsistor+tester
        Isn't that tool is only good if the components are removed from the pcb? How would you use this tool to test ibgts and mosfets when they are on the pcb in circuit?
        Any multimeter, even the cheapest one that you get free at Harbor Freight, can test for a simple short.
        • johns1mj
          • May 2015
          • 242
          I want one tester that will do resistors, capacitors and igbt. I can not test if the mosfet or igbt will open and close. I could perform direct short tests but nothing else. I just bought a radio shack 2200087 it worked great on the igbt and mosfet but it only has a uf rating of 60. The Klein atleast went to 250 uf.
          • retiredcaps
            • Apr 2010
            • 9271
            Any multimeter will measure resistance. The cheaper ones, however, will only go to 2M ohm.
            Using a multimeter to measure capacitance is not as useful in troubleshooting because you are probably more interested in the ESR.
            There is no handheld multimeter that will measure ESR. You need a separate tool for this functionality. It could be one linked in the Amazon or some variation of it.
            Many multimeters will measure up to 10,000uF.
            Be aware that sometimes in circuit readings could be misleading due to other components in the circuit path. If you get suspicious readings in circuit, desolder and verify out of circuit.
            According to the manual, the 2200087 has
            DIODE MODE
            Open Circuit Voltage ................. < 2.8Vdc
            Test Current ........................ 1 mA Typical
            So it is almost double the open circuit voltage and almost double the test current compared to the Klein.
            PS. I think this meter was selling for $10 USD when Radio Shack initially filed for bankruptcy.
            • culcuhain
              • May 2016
              • 186
              • U$@
              True. This is a good tool to test your replacement parts before replacing and confirming parts with issues. It is good for testing unknown parts too.... just another tool in the tool box. I have 3 other multimeters (one is the free harbor freight) and 2 oscilloscopes.
              • dmill89
                • Dec 2011
                • 2534
                Most of the time I use a Harbor Freight "CEN-TECH" P37772, good enough 90% of the time and cheap enough (Your Klein MM200 is a better meter than this, but you can pick the HF P37772 meters up for $10-15 on sale, so they're often good to have around) I'm not worried about damaging it. If I need higher precision I dig out the Extech MM570.
                • johns1mj
                  • May 2015
                  • 242
                  So, the general consensus is no matter what you will always need multiple testers.
                    BTW, 1.5V Diode mode test is too low to test White LED.
                      Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                      This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                      09-06-2024, 09:10 PM
                      Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                      This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                      This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    • electronx
                      Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                      by electronx
                      I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                      1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                      According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                      If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                      06-26-2025, 03:27 AM
