Sony KDL-40Z4100 3/4 of the panel is distorted and full of lines
  • lucidbarrier
    • Jul 2012
    • 84
    Sony KDL-40Z4100
    My buddy had this tv mounted on his wall. He told me it was ghosting and I thought it may be a t-con as15 chip.
    Then I got it home, turned it on with my Hisense Sero 7 pro tablet connected via mini hdmi and then I saw this mess. It turns on and lights up but about 3/4 of the screen is just lines and smeared. The top portion seems to work but very very slowly. It seems to bleed downward and the image is hazy and ghosts during movement. It looks like the tv is having an acid trip.
    When I press the input button on the side of the panel the TV is very slow to respond and require multiple button pushes. Volume and power work fine. The audio is clear and loud. I tried mulitple HDMI ports to try to see if one of them is bad but it is difficult to ascertain which input you are on since the letters seem to bleed into each other but on all the inputs it's the same.
    I was initially thinking it was the t-con but I kind of wonder if this is just a bad panel?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-40Z4100 3/4 of the panel is distorted and full of lines
    IMHO it looks like a bad panel
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      +1 not fixable.
      • lucidbarrier
        • Jul 2012
        • 84
        Awesome, thanks guys.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • Chrissygizmo
          Sony KD-55XG9505 lines on screen problem
          by Chrissygizmo
          Hello again everyone,
          This is my latest mission, to try getting this Sony tv back to normal working order…
          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
          02-19-2025, 11:31 AM
        • learnmore
          Samsung UE70TU7020K Which lines to tape on a bad panel
          by learnmore
          Hello Community,
          I'm working on a Samsung UE70TU7020K.
          It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
          I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
          03-15-2024, 03:01 PM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          11-18-2025, 02:09 AM
