Samsung PN50C450B1D
  • johns1mj
    • May 2015
    • 242
    Samsung PN50C450B1D
    OK I have a plasma tv pn50c450 that has sound but no picture.
    Tested the power supply with all boards connected, X SUS removed, Y buffer removed but x connected, and y buffer and x sus disconnected. on all 4 tests the Vs was between 203 and 205, 205 was on sticker. The Va was almost a solid 53 every time, 55 on sticker. The Vsc was supposed to be -178.
    All -90
    -x -83
    -y buffer -101
    -y buf -x -92
    The Ve was supposed to be 83. I never got a solid reading. It would jump from -300 to 50 and back and forth. Also on the tag there is a 2Ve reading of 71. I could not find the 2Ve test point. I assumed this was for a different model.
    I performed the quick test on the Y-buffer. Both middle connectors are shorted together on all pins.
    After all this I conclude the Y-sus board is bad and the Y-buffer is bad. The X boards will need to be tested once Working y boards are installed.
    Does this follow? Did I miss a step?
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Re: Samsung PN50C450B1D
    Theres a 99% chance buffer still good, but y sus bad. Look for pits and craters in the i/c chips on the buffer. If none. Then install y sustain and cross your fingers. I have heard of cases where buffer takes out new y sustain, but I tend to think of it as a old wives tale. I fixed 5 plasmas last 3 months. I didnt replace a buffer on any of them. Just y sustain and done!
    • rccrasher65
      • Mar 2014
      • 618
      I have boards for this set, no y main though!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ysus and Xsus are chained recovery in this set so bad Y can kill X and reverse, test all the main Igbt transistors on both the Y and Xmain they are on the heatsinks and surface mounted on the bottom side.
        • johns1mj
          • May 2015
          • 242
          I may get ahold of you for boards.
          • johns1mj
            • May 2015
            • 242
            For testing purposes is there a difference between mosfet and a igbt?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have a read of this buddy, mosfets and IGBTS can be test in the same way though with a multimeter in diode mode.
              http://www.differencebetween.com/dif...and-vs-mosfet/
              • johns1mj
                • May 2015
                • 242
                OK, a used y-sus just arrived. The y-sus is running -196 tag says -178. I do not find a variance listed anywhere. Is this to far out?
                • johns1mj
                  • May 2015
                  • 242
                  Ok, decided to try it.
                  VS 203 205 sticker
                  Va 53 55 sticker
                  Vsc -198 -178 sticker
                  Ve 85 83 sticker
                  I get a flash of light and then no picture and no back lights. I still have sound. The voltages then begin to drop.
                  What next?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    There are generally a few pots on the Ysus board for adjustment. Is there one for Vsc?
                    • johns1mj
                      • May 2015
                      • 242
                      The 3 adjustable pots all say VR- scan fr and rr. The board power up for 7 seconds and then drops.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        I think VR_VSCAN is Vsc but perhaps someone can confirm this before you alter it.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Yes adjust V-Vsc while monitoring the Vsc voltage. Might be best to keep it a couple volts higher as it will help remove any mal discharge in the screen quicker.
                          • johns1mj
                            • May 2015
                            • 242
                            I adjusted the Vsc to -180. I have removed all connectors but the power supply to the y-sus. The board holds power steady. I connected the y-buffer and tested, holding power steady. hooked up the x board Ve was down to 70, adjusted to 78(83 sticker). I do not have the lower boards that are attached to the screen hooked to the logic. The voltage dropped after 7 seconds. I attached all boards and the same happened. I removed the ribbon between the logic and the y-sus. Everything checked normal voltage wise. However, I did not get the back light flash like when the logic was hooked up. The green light is flashing once a second on the logic board. disconnect all ribbons but the y-sus to the logic board and same results, light one second off and 4 seconds on.
                            This leads me to believe I also have a bad logic board. Did a quick check for shorts and didn't fine any.
                            Any advice for testing before I order a logic board?
                            • rccrasher65
                              • Mar 2014
                              • 618
                              Send me Pm. I have new logic board, Xmain, and main board.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                So what happens if you disconnect the Ysus or Xsus power do the voltages stay ?
                                • johns1mj
                                  • May 2015
                                  • 242
                                  Voltages only drop if tcon is connected to the ysus
                                  • tvsteve2
                                    • Aug 2014
                                    • 25
                                    • usa
                                    You mean Control board as Plasmas DON'T have T-cons!
                                    • johns1mj
                                      • May 2015
                                      • 242
                                      Technically Samsung named it a logic board.
                                      • rccrasher65
                                        • Mar 2014
                                        • 618
                                        Is this the board you need? main logic board.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
