Samsung PN50C450B1D
  • johns1mj
    • May 2015
    • 242
    Samsung PN50C450B1D
    OK I have a plasma tv pn50c450 that has sound but no picture.
    Tested the power supply with all boards connected, X SUS removed, Y buffer removed but x connected, and y buffer and x sus disconnected. on all 4 tests the Vs was between 203 and 205, 205 was on sticker. The Va was almost a solid 53 every time, 55 on sticker. The Vsc was supposed to be -178.
    All -90
    -x -83
    -y buffer -101
    -y buf -x -92
    The Ve was supposed to be 83. I never got a solid reading. It would jump from -300 to 50 and back and forth. Also on the tag there is a 2Ve reading of 71. I could not find the 2Ve test point. I assumed this was for a different model.
    I performed the quick test on the Y-buffer. Both middle connectors are shorted together on all pins.
    After all this I conclude the Y-sus board is bad and the Y-buffer is bad. The X boards will need to be tested once Working y boards are installed.
    Does this follow? Did I miss a step?
  • ozzy214
    • Nov 2013
    • 319
    • usa
    Re: Samsung PN50C450B1D
    Theres a 99% chance buffer still good, but y sus bad. Look for pits and craters in the i/c chips on the buffer. If none. Then install y sustain and cross your fingers. I have heard of cases where buffer takes out new y sustain, but I tend to think of it as a old wives tale. I fixed 5 plasmas last 3 months. I didnt replace a buffer on any of them. Just y sustain and done!
    • rccrasher65
      • Mar 2014
      • 619
      I have boards for this set, no y main though!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ysus and Xsus are chained recovery in this set so bad Y can kill X and reverse, test all the main Igbt transistors on both the Y and Xmain they are on the heatsinks and surface mounted on the bottom side.
        • johns1mj
          • May 2015
          • 242
          I may get ahold of you for boards.
          • johns1mj
            • May 2015
            • 242
            For testing purposes is there a difference between mosfet and a igbt?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have a read of this buddy, mosfets and IGBTS can be test in the same way though with a multimeter in diode mode.
              http://www.differencebetween.com/dif...and-vs-mosfet/
              • johns1mj
                • May 2015
                • 242
                OK, a used y-sus just arrived. The y-sus is running -196 tag says -178. I do not find a variance listed anywhere. Is this to far out?
                • johns1mj
                  • May 2015
                  • 242
                  Ok, decided to try it.
                  VS 203 205 sticker
                  Va 53 55 sticker
                  Vsc -198 -178 sticker
                  Ve 85 83 sticker
                  I get a flash of light and then no picture and no back lights. I still have sound. The voltages then begin to drop.
                  What next?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    There are generally a few pots on the Ysus board for adjustment. Is there one for Vsc?
                    • johns1mj
                      • May 2015
                      • 242
                      The 3 adjustable pots all say VR- scan fr and rr. The board power up for 7 seconds and then drops.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        I think VR_VSCAN is Vsc but perhaps someone can confirm this before you alter it.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Yes adjust V-Vsc while monitoring the Vsc voltage. Might be best to keep it a couple volts higher as it will help remove any mal discharge in the screen quicker.
                          • johns1mj
                            • May 2015
                            • 242
                            I adjusted the Vsc to -180. I have removed all connectors but the power supply to the y-sus. The board holds power steady. I connected the y-buffer and tested, holding power steady. hooked up the x board Ve was down to 70, adjusted to 78(83 sticker). I do not have the lower boards that are attached to the screen hooked to the logic. The voltage dropped after 7 seconds. I attached all boards and the same happened. I removed the ribbon between the logic and the y-sus. Everything checked normal voltage wise. However, I did not get the back light flash like when the logic was hooked up. The green light is flashing once a second on the logic board. disconnect all ribbons but the y-sus to the logic board and same results, light one second off and 4 seconds on.
                            This leads me to believe I also have a bad logic board. Did a quick check for shorts and didn't fine any.
                            Any advice for testing before I order a logic board?
                            • rccrasher65
                              • Mar 2014
                              • 619
                              Send me Pm. I have new logic board, Xmain, and main board.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                So what happens if you disconnect the Ysus or Xsus power do the voltages stay ?
                                • johns1mj
                                  • May 2015
                                  • 242
                                  Voltages only drop if tcon is connected to the ysus
                                  • tvsteve2
                                    • Aug 2014
                                    • 25
                                    • usa
                                    You mean Control board as Plasmas DON'T have T-cons!
                                    • johns1mj
                                      • May 2015
                                      • 242
                                      Technically Samsung named it a logic board.
                                      • rccrasher65
                                        • Mar 2014
                                        • 619
                                        Is this the board you need? main logic board.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
