Sanyo DP50741 buffer board question
+ More Options
Posts
  • nwcs
    • Dec 2015
    • 311
    • usa
    I have a water damaged cable on the su (one on the right) buffer board and can not find a part number for it anywhere. It is at location c23 on the buffer board and ss23 on the ss board. Does any one know the part number for the flat cable or have one in there inventory they want to sell. I have the tv put back together or I would have a picture of it.
  • tw2005
    • Oct 2011
    • 6458
    Re: Sanyo DP50741 buffer board question
    Confusing information, SU or SS? You're quoting SS and C board connector locations.
    Since this TV is based on a Panasonic try searching these eg TC-P50C2, 50PX24, 50X2.
    There are a few cables on Ebay for sale. I can find the 42" one.
    Measure yours, my 42" lead is about 185mm. Being a larger model that lead is probably longer but you may be lucky as they all use TNPA5072 SS boards.
    Connectors at ss23 and c23 should be a 6p right angle connector. Both ends should be the same
    K1KY06AA0719
    https://www.encompassparts.com/item/...0719/Connector
    make a new one or reterminate. could not see a part number for the cable in the manuals.
    Pay attention to how the wires run to each connector as pin 1 goes to 1, 2 to 2 etc,
    This set appears to have one, top left with the ribbons in the image.
    http://www.ebay.com/itm/Sanyo-Model-...wAAOSwu4BV12VY
    • nwcs
      • Dec 2015
      • 311
      • usa
      So I finally got around to making a replacement cable and that went well but since the su board is bad it still just turns on and off continuously so I will order the buffer board and hope for the best.
      • tw2005
        • Oct 2011
        • 6458
        Are you talking about the SU board
        Or the SS
        If it's the SU, have you tried isolating the SD & SU boards and turning it on?
        If you believe the SU is causing it to cycle then by rights if you disconnect the SU & SD boards from the SC, remove the 4 Vfg bolts from the sd/su, jumper the 2 pins on the SC at sc50 it should turn on and stay on.
        If it still displays the same symptoms then it could be something else.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
