I have a water damaged cable on the su (one on the right) buffer board and can not find a part number for it anywhere. It is at location c23 on the buffer board and ss23 on the ss board. Does any one know the part number for the flat cable or have one in there inventory they want to sell. I have the tv put back together or I would have a picture of it.
Sanyo DP50741 buffer board question
Re: Sanyo DP50741 buffer board question
Confusing information, SU or SS? You're quoting SS and C board connector locations.I have a water damaged cable on the su (one on the right) buffer board and can not find a part number for it anywhere. It is at location c23 on the buffer board and ss23 on the ss board. Does any one know the part number for the flat cable or have one in there inventory they want to sell. I have the tv put back together or I would have a picture of it.
Since this TV is based on a Panasonic try searching these eg TC-P50C2, 50PX24, 50X2.
There are a few cables on Ebay for sale. I can find the 42" one.
Measure yours, my 42" lead is about 185mm. Being a larger model that lead is probably longer but you may be lucky as they all use TNPA5072 SS boards.
Connectors at ss23 and c23 should be a 6p right angle connector. Both ends should be the same
K1KY06AA0719
https://www.encompassparts.com/item/...0719/Connector
make a new one or reterminate. could not see a part number for the cable in the manuals.
Pay attention to how the wires run to each connector as pin 1 goes to 1, 2 to 2 etc,
This set appears to have one, top left with the ribbons in the image.
http://www.ebay.com/itm/Sanyo-Model-...wAAOSwu4BV12VYLast edited by tw2005; 07-15-2016, 06:21 PM. -
Are you talking about the SU board
Or the SS
If it's the SU, have you tried isolating the SD & SU boards and turning it on?
If you believe the SU is causing it to cycle then by rights if you disconnect the SU & SD boards from the SC, remove the 4 Vfg bolts from the sd/su, jumper the 2 pins on the SC at sc50 it should turn on and stay on.
If it still displays the same symptoms then it could be something else.Last edited by tw2005; 07-21-2016, 09:12 PM.Comment
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
