Can't get out of hotel room mode with LG 37LC5DC-UA
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    I have picked up and fixed LG 37LC5DC-UA. While it works fine, I don't have access to re-scan channels or change picture settings. I do have the remote.
    I have tried various online recommendations, but none worked. Press and hold menu then 1105, press and hold menu or OK on both TV and remote. press the reset button on the back of the TV, while the TV is on, while off, and white turning on. None helped.
    Any other thoughts on what else I can do?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Can't get out of hotel room mode with LG 37LC5DC-UA
    The following was taken from the web which does looks similar to what you say you have tried.
    To enter Installation menu from the remote control, you need:
    Choose any TV channel (it might not work if other input is selected)
    Press and hold MENU button on the remote control until TV's menu appears, disappears and channel info appears.
    Quickly release MENU button, enter 1105 and press OK.
    If your remote control has no MENU button, use HOME button instead.
    There's also this page
    http://www.askvg.com/secret-service-...ony-and-lg-tv/
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      I have tried that already, and many other combinations of buttons and numbers.
      However, I have figured it out. I have taken the TV apart again. The tuner is separated from the main board. There is a coax cable and set of other cables connected between the main board and the tuner board. I have disconnected the set of cables from the tuner board, and the TV stopped behaving as Hotel TV. See attached picture
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Its probably be uase its set to switch the Tv to hotel mode if thats connected-hotel mode device only.
        • Diah
          • Feb 2013
          • 6581
          you can use smart remote on android if you have mobile with IR sender. so you can use INSTOP function, it will erase all setting.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Does a 1980's brick phone have one built in or can I solder it on ?
            • Diah
              • Feb 2013
              • 6581
              it seem you are out dated.. update yours equipment to 2016 LOL
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ohh I see haha
                • Woodsworth
                  PS3 CECHC03 60GB YLOD Troubleshooting
                  by Woodsworth
                  I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                  START
                  Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                  03-19-2024, 07:58 AM
                • elpatxi_bcn
                  Samsung HG75EJ690UB Hotel TV, change main?
                  by elpatxi_bcn
                  Hello!
                  I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                  Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                  The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                  05-19-2023, 03:21 AM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Kezi Gamer
                  Marshall stanmore multi room
                  by Kezi Gamer
                  Hi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated​...
                  03-24-2025, 08:37 AM
                • BMCappelletti
                  Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                  by BMCappelletti
                  Hi everyone.
                  Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                  Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                  Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                  02-18-2025, 12:22 PM
