Philips 32PFL3008H strange backlight problem
  • gurug
    • Mar 2015
    • 27
    • Slovenia
    Hello to all!
    I repaired philips 32pfl3008h last week, changed 4 diodes in power supply and fuse. TV started working again. But now I see that randomly after from 2 to 4 hours of tv on, backlight turns off... Sound plays on. After I switch tv off and on again, it works again for few hours...
    Can anyone point me in right direction what should I also check?
    Thanks in advance.
  • gurug
    • Mar 2015
    • 27
    • Slovenia
    Re: Philips 32PFL3008H strange backlight problem
    Originally posted by gurug
    Hello to all!
    Thanks in advance.
    Problem solved, it was one LED not working in backlight...
    • janos6662000
      Philips 47PFS7509/12 LCD TV problem
      by janos6662000
      Hi
      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
      When i applied cable signal to check image, i had normal picture, but TV was restarting.
      I downloaded original firmware and applied the update, but the problem remained.
      From a colleague i received a "factory package software" which is a lot bigger.
      I made another firmware update, but still did not solve the problem.
      Somewhere on the way the error got worse, because at the moment the...
      08-12-2025, 12:54 PM
    • chestercc
      Philips TV Backlight Repair
      by chestercc
      So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
      My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
      The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
      11-18-2022, 01:15 PM
    • ohren
      Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
      by ohren
      I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
      The setup is basically:
      Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
      Transistor is switching the 3.5 V supply on the power board....
      12-05-2024, 11:10 AM
    • Dobrowol
      Asus GA402RK keyboard and kb backlight problem
      by Dobrowol
      Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
      04-28-2025, 04:30 PM
    • Xristakis795
      42pfl5405/h05 philips lcd tv backlight problem
      by Xristakis795
      Hi i have the above tv and has backlight problem
      I noticed with a flashlight that I have picture and sound when I put an antenna
      My problem is that I do not have a device to test the fluorescent lamps and extend the transformer high to see which of the two is to blame and to give a solution to my problem
      I was thinking an easier solution would be to turn the TV into a LED but I had done it before in another (different model) and it looked like bright dots behind the lcd panel and it was ugly
      What do you recommend ?
      07-04-2021, 03:39 PM
