42pfl5405/h05 philips lcd tv backlight problem
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Hi i have the above tv and has backlight problem
    I noticed with a flashlight that I have picture and sound when I put an antenna
    My problem is that I do not have a device to test the fluorescent lamps and extend the transformer high to see which of the two is to blame and to give a solution to my problem
    I was thinking an easier solution would be to turn the TV into a LED but I had done it before in another (different model) and it looked like bright dots behind the lcd panel and it was ugly
    What do you recommend ?
  • petehall347
    • Jan 2015
    • 4438
    Re: 42pfl5405/h05 philips lcd tv backlight problem
    i used to test inverters with spare tubes i had lying around .
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      you mean the room is dark and I get a fluerecent lamp
      to pass it over the transformer and if it lights up it means that the transformer is good;
      But if one of the panel lamps has a problem, the inverter circuit will not be protected, so it will not give voltage to the Transformer;
      • petehall347
        • Jan 2015
        • 4438
        no i used tubes from old panels and wired them up .
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          aaa i understood
          in my case only two cables leave from the inverter to the ccfl lamps
          How did he do it, did he connect them in parallel?
          Can I disconnect these cables and put them in a single functional ccfl lamp to see if the inverter is to blame?
          • janos6662000
            Philips 47PFS7509/12 LCD TV problem
            by janos6662000
            Hi
            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
            When i applied cable signal to check image, i had normal picture, but TV was restarting.
            I downloaded original firmware and applied the update, but the problem remained.
            From a colleague i received a "factory package software" which is a lot bigger.
            I made another firmware update, but still did not solve the problem.
            Somewhere on the way the error got worse, because at the moment the...
            08-12-2025, 12:54 PM
          • chestercc
            Philips TV Backlight Repair
            by chestercc
            So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
            My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
            The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
            11-18-2022, 01:15 PM
          • ohren
            Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
            by ohren
            I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
            The setup is basically:
            Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
            Transistor is switching the 3.5 V supply on the power board....
            12-05-2024, 11:10 AM
          • Dobrowol
            Asus GA402RK keyboard and kb backlight problem
            by Dobrowol
            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
            04-28-2025, 04:30 PM
          • fanaticgames
            Samsung UE32D4010 Backlight problem, led ok
            by fanaticgames
            hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
            02-22-2023, 09:46 AM
