Sylvania LD320SSX Flashing Color Test Pattern
  • Shane711
    • 493
    I got a Sylvania LD320SSX and it flashes multiple colors on the screen, the Color Test Pattern.
    I am thinking it is the EEPROM but after contacting ShopJimmy they are saying if it is not listed on the page that it fixes that problem then it won't. I have proved them wrong before. When you contact them you are not always answered by a technician.
    I thought when any TV is stuck in the Color Test Pattern it was a bad EEPROM.
    So I would like an expert to confirm this for me or tell me why the EEPROM may not be the problem?
  • Diah
    • Feb 2013
    • 6399
    Re: Sylvania LD320SSX Flashing Color Test Pattern
    as you know eeprom saved the programmed data and provide this date to microprocessor at start on, microprocessor can changed setting and order which will be saved at eeprom. Test pattern are functional at microprocessor when its ordered as fault always from microprocessor the eeperom will save this change. also even you change new eeprom the microprocessor will write this fault again at the eeprom
    also focus on reset microprocessor to rewrite the correct order at eeprom at next turn on.
    • CapLeaker
      Leaking Member
      • 8222
      Does the TV respond to anything else than the power button? You got a remote for it? I would agree with doing a factory reset. I don't think that the EEprom is bad itself, because it would do more queer stuff, I would think. Maybe the TV was in service mode and someone didn't exit it correctly?
      • Shane711
        • 493
        I don't have a remote, I have a universal. I am not sure how to do a factory reset on this TV. I have the Service Manual here but I do not see anywhere in it about a factory reset.
        • vinceroger69
          • Mar 2012
          • 6714
          http://www.justanswer.com/tv-repair/...0ssx-just.html
          you will really need a original remote i think to get out of the test pattern mode
          • capwizard
            • Jun 2016
            • 1991
            Sylvania LD320SSX is a DVD combo tv made by Funai (Emerson)(Japanese brands)
            you definitely need to get the remote controller. (NF000UD Remote Control*).
            * Here is A cheap one.
            http://www.ebay.com/itm/NF000UD-T2-4...0AAOSwmtJXadcZ
            Don't forget:
            there is a hidden button you cannot see it and you must peel the plastic front off the remote to get to it and this will put you in service mode by hitting this button once.
            if I remember correctly the service button (red or gray color) is under the eject button.
            After you get the remote ,see if you can read the service-mode-remote-code.
            Because some remote can learn and save the code.
            Turn Your iPhone into a Universal Remote
            http://gizmodo.com/5982909/5-apps-to...iversal-remote
            5 Best Universal Remote Apps for Android
            http://joyofandroid.com/best-univers...s-for-android/
            • cliff_hootarski
              • Jul 2006
              • 411
              Here is an Emerson remote showing where to cut the plastic to access the hidden menu.
              Cut out above the "Audio" button.
              • capwizard
                • Jun 2016
                • 1991
                O.wo.. Thank you, so could you please read the service code for us, will be helpful for us.
                EEVblog #506 - IR Remote Control Arduino Protocol Tutorial
                https://www.youtube.com/watch?v=BUvFGTxZBG8
                Smart Remote Control
                https://www.youtube.com/watch?v=Q_-fiPSk7DI
                How to control your TV with an Arduino!
                http://www.instructables.com/id/How-...th-an-Arduino/
                • cliff_hootarski
                  • Jul 2006
                  • 411
                  Here is a picture of the screen when the "secret button" is pushed when the TV is "On".
                  Where to go from there is anybody's guess.
                  I did press the "Left Arrow" button and it started to display full mono color screens.
                  Thought it was stuck in this mode but I pressed some key or series of keys and the TV came back to the regular screen.
                  Kinda afraid to press any other keys and mess up a working TV. (Wife's TV in the kitchen).
                  • Diah
                    • Feb 2013
                    • 6399
                    the easy way download the last firmware and put it on usb and insert it at the usb port at the side of the TV. then lug it to wall socket. this will make rest too. read more how at your service manual
                    http://www.funai-corp.com/support/Firmwares.aspx
                    • Shane711
                      • 493
                      I just ordered the remote that capwizard mentioned. He was right, that is pretty cheap. I will let you all know what happens.
                      • Shane711
                        • 493
                        I got the remote I ordered today, had a little trouble but got it figured out.
                        The secret button is actually at the bottom of the remote under the Title button. I followed the directions and presto, the TV is now working. I am relieved.
                        • capwizard
                          • Jun 2016
                          • 1991
                          Thanks for the update.
                          • CapLeaker
                            Leaking Member
                            • 8222
                            aah... there we go! perfect!
                            • Shane711
                              • 493
                              So I had another main board for the same TV that had the same problem. I switched out the boards and fixed that one too. Now the DVD player don't work so I have to fix that. I also have a Insignia doing the same thing but I forgot where I put it so I am going to drag that one out and see what I can do with it.
                              • capwizard
                                • Jun 2016
                                • 1991
                                Good! I like your zero waste lifestyle.
                                • Shane711
                                  • 493
                                  Well, the DVD player was completely dead, couldn't get it to do anything. I swapped it out with another and it is working perfect.
                                  Note to all: If your DVD player in your combo TV has a problem accepting DVDs or ejecting them the fix is very simple. Clean the rubber roller inside with rubbing alcohol.
                                  • Stephanie2017
                                    • Apr 2017
                                    • 6
                                    Please help! My tv is doing the same thing and I'm clueless
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      Same thing?
                                      Flashing colours and the remote control is not resetting it, or the DVD not working?
                                      • Shane711
                                        • 493
                                        You have to peel back the sticker where the buttons are to uncover the special buttons. The secret button is actually at the bottom of the remote under the Title button. Just follow the directions on this thread.
                                        • Jeryswan
                                          Intermittent color test pattern issue.
                                          by Jeryswan
                                          I've got a LN-T4065F which came into my shop with the customer complaining that the test patterns would randomly come up on the screen. Upon testing, the pattern came up on the screen after about 20 minutes of use. We opened it up and did a visual inspection to see if there was any dust or bugs shorting out anything on the board that would generate the test patterns. I'm a bit new to TV repair but on a plasma tv that we recently worked on we strapped out the auto ext on the control board and it generated test patterns on the screen. My thoughts was that maybe something was shorting out that circuit.......
                                          10-14-2020, 03:21 PM
                                        • SidneyCanadas
                                          93C46 and 93C56 EEPROM
                                          by SidneyCanadas
                                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                          06-14-2023, 01:16 PM
                                        • m3tal82
                                          Sony Bravia XBR-65x900e Test pattern
                                          by m3tal82
                                          Hello all,
                                          I got this beauty of a 65" Android Smart TV from a roommate whose boss through it out because it didn't work. I've fixed a few TVs before, but was being stupid on this one:
                                          Original issue:
                                          TV powered down after a minute or so, but picture was fine.
                                          Tried replacing main board, which didn't work. I should have just replaced the AC Power board.
                                          Months later, I replaced the power board, so I can see the screen. I lost / threw out my original main board, and there is now what I believe to be a defective main board in the TV. My symptoms...
                                          04-07-2020, 12:41 PM
                                        • YellowJacket
                                          SHARP LC-32CHF5111K - stuck at color test mode
                                          by YellowJacket
                                          Hi friends,
                                          TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                          So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                          02-04-2023, 03:11 AM
                                          HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-06-2024, 08:23 AM
