Samsung UN60EH6003 goes black during video games and requires power cycle
  • sharppa
    • Jun 2016
    We have a 13 month old Samsung 60" UN60EH6003 TV that has been acting up recently. During heavy video game usage, the screen will go black, the blacklight will be visible (screen has glow) and the TV requires shutting it down and back on for the screen to come back on. This happens both with an XBox one and a PS4 through a Sony receiver with HDMI cables. More active games seem to cause it more frequently. The remote works while the screen is black to shut it off but the on screen menus do not appear. We don't have sound through the TV so I'm not sure if sound is working when the video goes dead.
    If we leave the XBox one just sitting at a home menu screen the problem does not happen. It only appears to happen when the TV is working harder to render a changing screen.
    I switched the TV to "game mode" yesterday without any success.
    I updated the firmware to the latest (1012?) off the Samsung website a few hours ago without any change.
    Any ideas what might be the problem? I see a three board repair kit on eBay for $95 for my model so could start swapping out boards if need be.
    Our house is 78 degrees or so in summer so maybe the TV is getting too hot and hitting some thermal shutdown? A sunny window is behind it so we just starting blocking that to see if that might help.
    Any suggestions would be greatly appreciated. Thanks.
  • zen
    • 511
    Re: Samsung UN60EH6003 goes black during video games and requires power cycle
    Hi guys
    Not familiar with this specific model , but does seem like main CPU might be overheating with the more demanding video content , unless there's a separate video processing chip .
    Might be worth renewing thermal paste .
    • neilc6
      • Nov 2015
      • 1550
      Known issue with the tcon board in that model. Search the part number on ebay for repair services. There is one for $25.
      • neilc6
        • Nov 2015
        • 1550
        https://www.badcaps.net/forum/showthread.php?t=51623
        https://ebay.us/QYesjf
        • zens electronics
          • Jan 2021
          • 31
          Hi Neil
          Description of fault repair service on E BAY link doesn't quite match the problem mentioned .
          Would still be interesting to know what fails on the T-CON
          Keep up the good work.
          Regards Zen
          • neilc6
            • Nov 2015
            • 1550
            I have the same model waiting for a new tcon board since I can't access the repair service from Canada. TV turns on with backlight but no video. This is a symptom of a bad tcon board. The repair kits include one IC and two caps.
            • diif
              • Feb 2014
              • 6978
              • England
              It's the ISL9860 ic that goes faulty. The caps are 2.2uf 50v ceramics. About $1/£1 for parts.
              https://www.youtube.com/watch?v=iuHrnvAKlGw
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
              • nono34
                Hisense stuck in Colors cycle like test pattern.
                by nono34
                I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                10-24-2024, 04:31 PM
              • Yoda79
                Samsung ue55nu7021k Boot cycle
                by Yoda79
                Hi, wondering if anyone can help with a tv which seems to turn on but turn off soon after and continue to do this cycle over and over again.
                It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the back and can see the backlights turning on. However when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
                Any thoughts, any help would be greatly appreciated.​...
                06-30-2024, 03:43 PM
              • survivalbloke
                Xbox Series X - crashing to dashboard shortly after launching games
                by survivalbloke
                Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                09-18-2024, 11:54 AM
