Insignia NS-48D510NA15 no backlight
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Insignia NS-48D510NA15 no backlight
    Originally posted by budm
    I use the strip for under counter lights.
    Good call. It'd be a snap to build a basic power supply and shazam!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • neilc6
      • Nov 2015
      • 1550
      If you want to isolate the failed LED, you can use a multimeter in diode test mode. If there are no test points, scrape the soldermask beside each LED.
      • davery
        • Nov 2020
        • 6
        Newbie here. I also have the Insignia NS-48D510NA15 with no backlight. I was able to take it apart and used two 9V batteries in succession to test each strip. One strip appears to be bad, as I could not get it to light up. Should I assume when one strip is bad, none will light up? If so, should I replace the one bad strip or all of them? Thanks for any help. As I said, I am a newbie with TV's, so any help would be appreciated.
        • neilc6
          • Nov 2015
          • 1550
          All the LEDs have wear and the ones still working are likely to fail. If you don't want a repeat failure, replace all of them with new and turn down the backlight level.
          • davery
            • Nov 2020
            • 6
            Thanks for the reply. Where is the best place to buy the LED's? How do you turn down the backlight level? Thanks for your help.
            • neilc6
              • Nov 2015
              • 1550
              Ordered these recently. They were a little bit thinner than the original strips so just taped them down with shipping tape. You can turn down the backlight in the picture settings menu. I would also turn off the ambient light sensor.
              https://ebay.us/9AkX9X
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
