Vizio E420i-a0 Vertical Lines
  • mitchkramez
    • Sep 2009
    • 19
    Hello everyone. Fixed a handfull of tv's with this forums help over the years, hoping to add one more to the pile!
    I have a Vizio E420i-a0 that has vertical lines when you turn it on, and DOES have sound. The vertical lines move and change. TV turns on and off fine otherwise.
    I have a few photos of the issue here, and video on youtube:
    - http://ep.d.pr/1jrCI/ksU63Lzi
    - http://ep.d.pr/1ldxn/5cWwkics
    - http://ep.d.pr/11kpt/3WVTiFlp
    https://www.youtube.com/watch?v=XdfCw5-tr9E
    Anything else I can check or is this just a mainboard failure - or is this full on panel failure?
    Thanks for the help!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vizio E420i-a0 Vertical Lines
    Panel failure, address driver fault dont spend a penny on it. No fixable sorry
    • mitchkramez
      • Sep 2009
      • 19
      Reecey - Thanks - i was afraid of that, but figured it was worth a shot. On the plus side, I have a ton of good parts to sell
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        No worries, keep the Led backlights for it Also what Panel is it can I ask ?
        • mitchkramez
          • Sep 2009
          • 19
          it's an LG panel. I can get you more details if you want when I'm back at home. Are you saying keep the backlights for selling them?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok, also up to you might be handy to keep them or sell whatever you decide to do
            • brad2157
              Vizio E70-E3 Two white vertical lines
              by brad2157
              I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
              Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
              Replacement main board - Boots up fine, but starting...
              12-13-2021, 05:11 PM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              Yesterday, 03:15 AM
            • viking509
              vizio e65 e3 LED tv color vertical lines center tv only
              by viking509
              I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
              03-21-2023, 12:48 AM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              Sadly it has vertical lines at the left and one line in the middle-right.
              I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
              I have factory resetted the TV as well but also with no luck.
              I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • visionbluedemon
              Help. Sony kd-65x85dj vertical lines
              by visionbluedemon
              First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
              Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
              tried blocking LC lines too, but same results
              is it lcd panel issue or tcon board issue?...
              07-25-2025, 04:56 AM
