LG 55LA740V Intermittent backlight band troubleshooting help.
  • Kastcool
    • Nov 2020
    • 5
    • España
    Re: LG 55LA740V Intermittent backlight band troubleshooting help.
    Hi. I am new here.
    I don't know if I'm doing it right, putting this thread back. If it's wrong, forgive me and put this answer where it should be.
    I have a LG55LA740s tv with more or less the same problem as Mano84 and Heder.
    In my case, the vertical dark areas are almost always the same as on their TV, but on other occasions, if we think of 6 vertical columns and we count them from left to right, the dark areas can be 3 and 5 or 2 and 3 or 1 and 6, etc ...
    To make it more complicated, I have noticed that the failure increases in winter. The screen turning off leaving only the sound (I don't know if it is a protection system or another failure).
    In summer, however, it almost does not fail.
    I have seen that Mano84 solved her problem by changing a led strip but in her case it seems that the fault was always in the same place. In my case it is intermittent and can be any strip.
    The black and white connectors heder talks about are listed as follows:
    Black connector on the left central side of the power board, from left to right: led +, NC, NC, NC, NC, VC4, VC5, VC6 View the front screen, this connector handles the right half.
    White connector on the central right side of the power supply board, from left to right: VC1, VC2, VC3, NC, NC, NC, NC, led +. Viewed from the front, this connector handles the left half.
    I measured as best I could the voltages on the black and white connectors on the top of the power supply and the most relevant was:
    The voltage on the led outputs, with the television being good or bad (with some shadow) is always approximately 87 volts except when the screen turns off completely, then it drops to 71 v.
    Outputs VC3 and VC5: The normal voltage is around 10 to 15 volts but when it fails it goes up to 30 volts and when the screen turns off (the sound remains), it seems to be stable again.
    I have seen that finally Heder did not tell us if he solved the problem.
    Can you give me some idea.
    Thanks and regards.
    • neilc6
      • Nov 2015
      • 1550
      Failing edge lit LED strips that are mounted horizontally will cause dark vertical bands. The LEDs will burn out especially if the backlight level is set to maximum. If it is intermittent, you can try turning down the backlight level and turn off energy saving mode.
      • Kastcool
        • Nov 2020
        • 5
        • España
        Okay. I'll try it and say something. Thank you
        • Kastcool
          • Nov 2020
          • 5
          • España
          Hi. Indeed, as Neilc6 said, the backlight was at maximum and a power saving mode was activated.I turn the light down to half and turn off the economizer. I turned off and on and the screen came out completely black. I turned off and on several times until the screen came out fine.
          It was like that all night and now comes the second part: At the end of the night there was a very good program and, since I have a disc connected to the TV, I put it on record.
          This morning the tv appears with black screen and there is no way it works. I observed that last night when I left it off and recording the red led that it has on the power supply flashed 5 times.
          This is not the first time this has happened. I have observed that the recordings on the hard disk do not go well either.
          I have seen that there are people who talk about failures in the soldering of the microprocessors and put the circuit boards in homemade ovens and say that they fix them.
          I'm not going to do this, but could the failure be due to a main board microprocessor soldering problem?
          Does anyone know if when the screen turns off completely it is a system protection or it is another failure?
          • Kastcool
            • Nov 2020
            • 5
            • España
            Problem solved.
            I write these lines to help anyone who has the same problem.
            The LG 55LA740S TV has a single strip of LEDs mounted on an aluminum plate located at the bottom and on top it has a sheet of some type of plastic that is what brings the lighting to the entire screen.
            That strip is the one that fails.
            When this type of failure occurs to you, stop worrying about it. It is the led strip.
            Greetings.
            • allrounder
              • Jul 2021
              • romania
              #26
              Originally posted by Mano84
              I have replaced the LED Strips on my 55LA790V, now the black bar problem is fixed. Thanks for the help.
              Hi Mano,
              I have exactly the same TV model and the same problem. Could you tell me where did you find replacement led strips for your tv?. I was looking all over the internet, no chance, only for 55LA7900 which is US model, another chassis. On the other hand maybe someone of you guys can recommend me a link or something, I don't want to disassemble the LCD panel without having the necessary strips. Any help will be highly appreciated. Thank you.
              • edugimeno
                Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                by edugimeno
                Hi There!
                I'm trying to help my friend who owns a restaurant be just bought.
                He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                It's stuck using, I guess, the 2 sided tape that comes with the strip
                The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                09-05-2024, 09:34 AM
              • osrex
                LED DRIVER KEEPS DYING
                by osrex
                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                i have no datasheet at all for the LED lights, all i have is its length.
                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                05-05-2025, 03:36 PM
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
              • howardc64
                LG 49UJ6500 LCD panel lighter band that goes away
                by howardc64
                49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                02-19-2023, 12:13 AM
              • charif
                Audio Driver for Thomson P14C4BK128
                by charif
                Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                Here are the details:
                • Model: Thomson P14C4BK128
                • Operating System: Windows 10 64-bit
                If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                Thanks in advance for your help!
                04-30-2025, 05:41 PM
