Sont KDL42EX440 power supply
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    I have 165 volts DC leg to leg on main cap..165 volts on center leg of one of the two transistors that are paired up, nothing on the other one beside it...measuring against negative side of main filter cap. No voltage anywhere to ground..I do not have any other dc voltage anywhere on the board.
    Set was totally dead..no standby LED. Any help is most appreciated.
  • CapLeaker
    Leaking Member
    • 8155
    Re: Sont KDL42EX440 power supply
    Check CN6401 and see if you really don't have 3.3V STBY. Check the resistance between the 3.3V pin and the GND pin, trace it back and make sure nothing is shorted in the secondary (rectifier diode, or bad capacitor) there.
    If you haven't luck in the secondary, check the primary STBY voltage part of the PSU where IC6301 (MIP2H2) is. Your reference GND for measuring DC in the primary circuit is the negative post of the big main filter capacitor.
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      I actually DO have 3.3 volts standby on the pin indicated. However, I do not have VCC 12V.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Now to figure out where the 12 volts comes from.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Or does it not develop the 12V until the main board tells it to come on?
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            Replaced one Schottkey Diode that tested bad out of circuit. I still have my 3.3 volts standby. Reinstalled board. No PS-ON/OFF voltage coming back from main. No standby LED.
            • CapLeaker
              Leaking Member
              • 8155
              You got a bad main board. PSon, DIM, BLon all comes from the main board. That tells the PSU and the backlights to turn on.
              To force the PSU on without the main board, jump 3.3V through a 1k resistor from 3.3V to PSon and from another 1k resistor from 3.3V to BLon. plug it in and all the voltage rails should be up and the backlights should be on.
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                ZY100110A is on the sticker on the main board.
                • ljintexas
                  LJinTexas
                  • Jan 2015
                  • 669
                  Here are the two labels on the board.
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    Reporting that replacement of the main board restored full functionality to this set.
                    Thanks to all!
                      12 volt switching power supply modification to 14.5 volts before blocking diode add
                      by sam_sam_sam
                      I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
                      I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
                      One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
                      04-11-2021, 11:01 AM
                      MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                      by sam_sam_sam
                      I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                      I open it up to find non brands name capacitors in it
                      I am not sure how this switching power supply is set up
                      Could someone please explain how this power supply works
                      Here is the capacitor ESR results
                      (1) 47uf@50 volts 0.46
                      (2) 47uf@50 volts 0.45
                      New 47uf@50 volts 0.35
                      (1) 100uf@25 volts 0.34
                      (2) 100uf@25 volts 0.35
                      New 120uf@50 volts 0.08
                      (1) 220@25 volts 0.13...
                      10-21-2018, 10:02 AM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • shamsudeen
                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                      by shamsudeen
                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                      07-19-2025, 07:14 AM
