Baird jo47.
  • benjamin.d.bird
    • Jun 2016
    • 45
    • United Kingdom
    Re: Baird jo47.
    The only settings in the factory settings sub menu are shipping mode, aging, factory channel and ssc adjust. Cannot find reset anywhere
    • vinceroger69
      • Mar 2012
      • 6714
      Re: Baird jo47.
      Maybe it is shipping mode? im sure ive read something about this doing a reset.
      • benjamin.d.bird
        • Jun 2016
        • 45
        • United Kingdom
        Re: Baird jo47.
        Any idea on the procedure
        • vinceroger69
          • Mar 2012
          • 6714
          Re: Baird jo47.
          no idea too be honest have you gone into shipping mode and looked whats available in that sub menu
          • benjamin.d.bird
            • Jun 2016
            • 45
            • United Kingdom
            Re: Baird jo47.
            Just asks for confirmation then powers down, when I power it up again same scenario
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              Re: Baird jo47.
              Im not sure what your next steps are then i guess either find another main board really cheap that matches your panel make etc or try a eeprom change but theres no gaurantee i guess its either of them i wonder if it could be a lcd panel issue? i just dont want you wasting your money on parts that may not be at fault.
              • domix
                AC unit bypass
                by domix
                i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
                Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
                how can i bypass this :/
                I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
                Today, 02:54 PM
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • sheffieldyorky
                ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                by sheffieldyorky
                Hey there people
                While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                This is what I tried, but not in any order.
                Google
                YouTube
                BIOS
                Command Prompt (administrator privileges)
                On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                10-25-2025, 02:22 AM
              • ngml
                Repair of an LG split AC system indoor unit PCB
                by ngml
                I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                This indicates an error in the communication between the outdoor and the indoor unit.
                The outdoor unit is fine, so the problem is the indoor PCB.
                The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                Does anybody have the schematics of this board,...
                02-01-2025, 12:55 PM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
