New Problem Sanyo 65" led
  • fullmore
    • Apr 2016
    • 25
    • usa
    So I had a problem with no picture but sound on this tv. I checked all the power readings, cables, screws, etc. Then I replaced all at once the t-con, main board, led invertor board, and FRC. I finally got a picture. But once I turned it off, it reverted back to the same sound but no picture.
    Upon multiple power up/offs the tv picture and sound came back up. Turned it off and back to sound but no picture. Repeated multiple power on/offs and got sound and picture. No certain number of times. I have had it work in 5-6 and had it takes 30+ power on/offs but the picture will work if I keep doing it.
    After the picture does come on, the tv has played just fine for over 11 hours straight. So since I replaced all those boards, there seems to be only the power supply board, led strips, and led themselves to blame. Im hoping its just the power supply, but is there anyway to check and make sure?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: New Problem Sanyo 65" led
    Photo's of the boards. Model number. All useful information when asking for help.
      Is it the same TV you have on this thread?
      https://www.badcaps.net/forum/showthread.php?t=53470
      • fullmore
        • Apr 2016
        • 25
        • usa
        Yep, tried to delete that thread and/or edit the title. I don't seem to be getting any responses and I wondered if it was the title. Now I have a new issue.
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • Dodgethis
          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
          by Dodgethis
          Hello all,
          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
          09-11-2024, 07:39 AM
        • computeka
          Macbook Air A2337 820-02016-07 No sound problem
          by computeka
          How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
          05-08-2024, 10:26 AM
