Sony Bravia XBR-55X850B - three blinks
  • Milburnt
    • Oct 2016
    • 8
    Re: Sony Bravia XBR-55X850B - three blinks
    Ok thanks for your help
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #42
      its just a big risk if its not a mainboard fault and you buy another and it does not solve the issue again hopefully another member may of had this issue before and have more tests etc you can run.
      • Biruslapio
        Panasonic P58V11B 8 and 12 blinks error "fix"
        by Biruslapio
        Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
        Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
        04-13-2021, 07:13 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
      • JUCaESAl
        Sony bravia KD-65AF9
        by JUCaESAl
        Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
        Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
        10-20-2025, 04:03 AM
      • Taurus12
        Optiplex 3050 micro 2 blinks followed by 3 blinks issue
        by Taurus12
        Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
        I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
        i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
        Any recommendation on what I have to do next? Thanks in advance
        06-10-2025, 05:05 PM
