79044120 Dell Monitor
  • NormanSaxon86
    • Mar 2012
    • 64
    I got this monitor and check used my multi meter to check the volts on the caps. I put my meter to 200 Ohms and then to DCV 20 so I could see the volt drop. I do not have a cap wizard or hany expensive tools like that.
    I want to get this monitor running lets see does anyone know what is a common part to go. I see cap kits for this board for $12 I could buy a used monitor of the same linkness at a thrift show for that of less.
    So looking for cost effectiveness I also plan to use this screen maybe hook up to my Phone or something.
    Micro usb to hdmi
    Power cable
    vga female hdmi
    Make sure your device is OTG Enabled. OTG Allows your device to communicate using USB.
  • NormanSaxon86
    • Mar 2012
    • 64
    Re: 79044120 Dell Monitor
    • NormanSaxon86
      • Mar 2012
      • 64
      Has anyone had problems heating the Solder it seems like it takes to long. I have used a candle with better results.
      Candle place board on aluminum shield and then pull bad capacitors when hot. Is it the solder gun I have or what it is 30w but it is not the best.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
      • ChristianBr01
        Dell 34 inch U3419W Monitor with thin stripes on partial screen
        by ChristianBr01
        I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
        This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
        This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
        Does someone have seen this before?...
        05-23-2025, 06:06 AM
