Samsung pn64e533d2f has sound no picture
  • nwcs
    • Dec 2015
    • 311
    • usa
    I have this plasma that the sound is fine just no picture. I have checked the buffer boards for shorts and found none. VA is 55V and VS is 143V roughly have what it should be. I unplugged the y main from the logic main and the voltage is now 217V which is the correct voltage. All other voltages are correct. I took the power supply out and found someone either did some repairs to it or checked so now I think it might be the power supply but I am not sure. I really need some help on this one.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung pn64e533d2f has sound no picture
    What voltages are given on the LCD panel. Can't quite make them out.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      So with the Ymain in Vs is low and woth it out it rises ? If so the Ymain has an issue. Also in a dark room does the screen glow ?
      • nwcs
        • Dec 2015
        • 311
        • usa
        to dick_barton what voltages do you need and to ReeceyBurger123 no glow at all.
        • nwcs
          • Dec 2015
          • 311
          • usa
          I was wondering if the logic main can cause this problem.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            These sets do have a notorious problem with bad solder joints on the power board,Q804,q805 if I remember correctly,but mainly all components on any heat sinks you need to really take a good look at the solder joints,even if they look good,re solder them.
            Also,can we see a pic of the "repair attempt" you saw on the power supply?
            Vs 143 volts is too low for sure. What exactly did you unplug to get the Vs to come back up to 215?
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • nwcs
              • Dec 2015
              • 311
              • usa
              I will get that back up and get the pictures.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                There's a label stuck on the back of the panel giving voltages such as VS=xx, VE=xx, VA= xx
                • nwcs
                  • Dec 2015
                  • 311
                  • usa
                  I unplugged the flat white ribbon cable coming from the logic main to the y main. I hope the picture of the voltages and the repair to the power supply might help.
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    I would first isolate the powersupply from all other boards and force it on via resistors,somewhere between 500 and 1000 ohm. ps-on to ground with one resistor and vs-on to standby 5 volts with one resistor.
                    Then measure the vs and va to see if they are correct,if they are I would put a load on them,to see if it can handle that or not.
                    Thatt way you know what board to target. I suspect the powerboard to be weak at best,considering they have a history to fail,and the repair attempt not looking too professional(solder joints look bad).
                    I might be staring blind here as all the pn64's I had here had a failed psu.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      So as martino said earlier VS is far to low so need to find out why. Have you checked for short/open circuits on your Ymain.
                      With the set off and all boards connected what resistance do you have from test points:- VSCAN to chassis and SVC_YOUT & SVC_VS to SVC_GND
                      Don't know how close to your set this Fastrack Guide is but it may help. Courtesy of Tom's Servive Manuals
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        I will try these out tomorrow thanks.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          Can you use two 115v bulbs in series to act as a load for the VS supply?
                          • martino
                            Not so "senior"
                            • Aug 2013
                            • 997
                            • canada
                            sure can. Not entirely sure what this psu could pull but I'd say two 100 watt bulbs would be enough of a load to test it.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Spot on.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Not even that for these, this set only uses about 210 watts, Vs will be about 160-180w of that Id say.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  No offence here your soldering on the Psu is not good. Get some solder with flux combination and resolder the joints again and clean with Ipa and a toothbrush.
                                  • martino
                                    Not so "senior"
                                    • Aug 2013
                                    • 997
                                    • canada
                                    I think he got it that way.
                                    • nwcs
                                      • Dec 2015
                                      • 311
                                      • usa
                                      I will have to look for the resistors unless I can use something else. As for the resistance checks here they are:
                                      Vscan to Chassis 3 ohm then it goes slowly down in value
                                      Svc_yout 152 ohm
                                      Svc_Vs 310 ohm then slowly goes down in value
                                      Svc-Gnd .8 ohm.
                                      and the service manual was helpful thanks.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        I'm no plasma expert but I would say that Vscan appears to have a low resistance and I wonder if you still have problems with the Ymain or the Y buffers.
                                        If anyone else can offer help at this point it would be appreciated.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
