Samsung main board BN97-05375B 0078 EEPROM Reset?
  • KenOlson
    • Jun 2011
    • 81
    Re: Samsung main board BN97-05375B 0078 EEPROM Reset?
    Hi vinceroger69,
    Thanks for the video link!!! Looks very interesting so using this info went to Google Play and found https://play.google.com/store/apps/d...m.remotefairy4
    As previously mentioned, like to read the user guide/man so Googled. To date have not found either but did find "10 best TV remote apps for Android" by JOE HINDY
    "Anymote Universal Remote (Smart IR Remote) [Price: Free / $6.99] Smart IR Remote is a go-to option for a lot of folks, despite how expensive it is comparatively speaking. It boasts support for over 900,000 devices and more is added on a frequent basis. What makes this remote interesting is that it’s not just for televisions. You can also control AC or Heating appliances, DSLR cameras, video game consoles, smart home equipment, set top boxes, and more, which a dedicated layout of controls for each category depending on what it is. It works quite well as long as your device is compatible and especially if you have a lot of smart devices."
    http://www.androidauthority.com/best...ndroid-607846/
    Ken
    • KenOlson
      • Jun 2011
      • 81
      Diah,
      "...Smart Remote, its handle allot of TV brands , projectors, HIFI, etc. and others home electronic sets, by TV all had access to service menu, and special service menu too."
      Any tips on using it with TVs?
      Thanks again for your suggestions!!!
      Ken
      • KenOlson
        • Jun 2011
        • 81
        victor_cj,
        "12 seconds is enough." Thanks for info!!!
        Have some projects to finish so when done will do.
        Ken
        • KenOlson
          • Jun 2011
          • 81
          Started this as a "Learning Project" and really appreciate everyones help!!!
          While I have little experience with digital LED TVs have repaired a number of PCs.
          In most cases (except for "Bad Caps"and "Blown Power Supplies") the problem has been corrupted software (all these PCs had Windows) so am asking is this a RF Quartz defect hardware problem as mentioned by Diah or corrupted software causing a loop?
          Beginners Question: All my friend wants to use this LED TV for is watching videos and viewing photos. Can this be done if there is a RF Quartz defect hardware problem?
          Am guessing Yes if the over air station scan is not used.
          Also appreciate any tips/suggestions setting up Samsung LED TVs for watching videos and viewing photos.
          Thanks again to everyone for your help!!!
          Ken
          • KenOlson
            • Jun 2011
            • 81
            victor_cj,
            Problem Connecting M_E_SCL and M_E_SDA
            After connected M_E_SCL and M_E_SDA plugged in TV and Standby Lite came on 1 time then nothing and Power On Button did not work.
            Removed M_E_SCL to M_E_SDA wire and when plugged in Standby Lite came on and Power On Button worked so fortunately there was No damage.
            Rewatched Video https://www.youtube.com/watch?v=DDzOSdfA41s M_E_Reset and M_E_SDA were connected for the samsung smart TV D5700 eeprom reset.
            Rechecked the BN97-05375B 0078 main board with a magnifying glass but did not find a M_E_Reset hole.
            Appreciate help!!!
            Ken
            • victor_cj
              • May 2015
              • 90
              • Romania
              #26
              In this case you need a eeprom programmer.
              The art of fighting without fighting
              • KenOlson
                • Jun 2011
                • 81
                #27
                victor_cj,
                As mentioned looked at BN97-05375B 0078 main board very closely.
                Am wondering if CN901_DEBUG (photo attached) is the EEPROM Reset is on this Main Board?
                Appreciate comments
                Ken
                • victor_cj
                  • May 2015
                  • 90
                  • Romania
                  #28
                  CN901_DEBUG is for UART communication, it is used to upgrade firmware factory level.
                  • lachbuster
                    • Dec 2017
                    hello fellow peers, scholars, and potential saviors...
                    ..after much searching for particulars about my problem with no luck, I thought to hijack this thread because the last post is just the segue to where I have wandered...
                    I have connected my PC to CN901_DEBUG out of desperation because of a firmware upgrade gone bad ( last thing displayed after reaching 100% was something like "unit will now power off for three seconds" ) - interestingly I discovered the need to set terminal baud rate to 38400 and the output is;
                    *MAIN
                    COLD Start
                    watch dog enable
                    LAST Power on
                    Start B Power Detect
                    Release MIPS
                    Hello A1
                    00442813
                    unsupport compress
                    set sound mode error1!!
                    Clock NG
                    ( then 'power up jingle' plays, STBY LED 6 flashes, then start again from *Main )
                    -essentially an infinite bootloop, minus backlight or sign of logo pixels, every 18 secs
                    -pauses after "COLD Start" while M_E_SDA shorted to M_E_SCL
                    -pauses after "unsupport compress" while M_E_SDA shorted to VCC or GND
                    -different board# than OP, but pictured holes/silkscreening/ICs are a match
                    -data on thumb drive used was since verified 100% against re'loaded FW from Samsung
                    -backlight illuminates when powered up, main board detached from PS
                    Would anyone venture to guess if there is recovery mechanism built into the initialization environment, much like found in routers - or is that just too impractical (fantasy) ? - only reserved for devices costing a fraction of what these command
                    Should I presume the flash is corrupt and not just the eeprom ? Or can the latter have such a dramatic effect ?
                    I'd really prefer the satisfaction of solving rather than board swapping - especially since there wasn't any 'problem' in short time since adopting it, that is until a fateful desire to update - if I can even be referred to the appropriate forum/resources, that too would be kind
                    -cheers
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      With the Samsung I have it's SDA and RESET that are bridged whilst the TV is powered on.
                      This I believe reloads the EEPROM data from the NAND, however if the NAND is faulty then that needs replacing for the procedure to work.
                      • thoma
                        • Sep 2012
                        • 268
                        https://forum.samygo.tv/
                        https://wiki.samygo.tv/index.php/UnB...y_EEPROM_Reset
                        http://tel-spb.ru/remont-tv-lcd/
                        • lachbuster
                          • Dec 2017
                          I concur that it requires a total boot to have the required functionality to perform eeprom regeneration, factory reset, enable ex-link port, etc - so whether caused by bad flash or fatal eeprom glitch, the problem can only be solved externally ( or with factory procedure/inside information ) - I will report back anything I learn that might help others - meanwhile thank you both for replying to me
