Samsung UN55ES7150FXZA power recycle
  • Audioplus
    • Feb 2012
    • 157
    Appx every 4 - 5 minutes this set turns off for about 1 - 2 minutes and will turn itself back on. I've replaced the Power Supply & Main Board, also provided firmware upgrades and same issue.
    Any chance of the T-Con or actual panel itself being bad?
    Thanks for the help!
    Dan C
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung UN55ES7150FXZA power recycle
    If you turn your backlight down say 50% will it stay on longer. Thinking led problem?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Very interesting.....Both Power and Main Boards changed and symptom still exists....well how about the Control Button Board.....That's the board with the Power, Volume up/down and Channel up/down switches also has the IR Receiver....
      • Audioplus
        • Feb 2012
        • 157
        It responds to the remote and hard buttons, if you go to Main Menu and try and access the Network Setup, the unit locks up, will still display picture (HDMI input) in background. Won't have any control of functions until the unit power off automatically and powers back on (the Samsung Logo stays lit) by itself. Then you have all remote control finctions for another 4 or 5 mins until unit shuts down for a minute again.
        • Audioplus
          • Feb 2012
          • 157
          FYI, the newer power supply & mainboard, issue was a little more often, appx every 3 mins it would turn off and come back on after a minute.
          • Audioplus
            • Feb 2012
            • 157
            Dick, I switched Dynamic to Standard setting, I assume that would use less output to LED's, no change
              How about disconnecting the WIFI card, control/IR board after the TV is powered on?
              • Truncatedhose
                • Oct 2014
                • 343
                I have this TV with the same symptom right now; anything ever get solved?
                • thoma
                  • Sep 2012
                  • 268
                  https://de.scribd.com/doc/232113793/...ng-Reset-Issue
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • mrtek
                    Samsung UN43NU6950FXZA No power
                    by mrtek
                    Hi
                    Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                    Main fuse = OK
                    Back light LED = OK. Power them with aux power source
                    LED output = OK 156V
                    I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                    Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                    07-20-2025, 08:06 PM
                  • hill01
                    Samsung UE75MU7009TXZG Endless Power Cycle
                    by hill01
                    Hi everyone and thanks in advance for any help I might get here
                    My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                    About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                    Since a few days, the TV won't turn...
                    11-17-2021, 02:52 PM
