17MB11-6 Vestel
  • ricoleal
    • Oct 2012
    • 9
    • Portugal
    17MB11-6 Vestel
    Hi, I've got a Growing Tv with Vestel chassis 17MB11-6 at my repair store. Someone tried to repair it, but was't able to do that, so he took parts out!! The board has the emi filter IC (ic36 3P2814AF) but xtal is missing, so no picture! Can anyone see wich xtal (x501) was there please? Thank you. Vestel schematics dont refer the frequency of the Xtal.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17MB11-6 Vestel
    Image of the board please ?
    • ricoleal
      • Oct 2012
      • 9
      • Portugal
      Re: 17MB11-6 Vestel
      This is the real board! As you can see x501 near pixelworks chip (metal one) is missing
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 17MB11-6 Vestel
        Right thats the clock crystal. Will have look see if I can find what value it is.
        • ricoleal
          • Oct 2012
          • 9
          • Portugal
          Re: 17MB11-6 Vestel
          Thank you
          • Diah
            • Feb 2013
            • 6364
            Re: 17MB11-6 Vestel
            take look on the base of the X500 if it paint it with white, if no it may X501 Optional however use same Hz value of X500 if don't make change then the fault at other parts..
            • ricoleal
              • Oct 2012
              • 9
              • Portugal
              Re: 17MB11-6 Vestel
              I'll try it monday and i'll tell you thank's. x500 is present, value 14.318180. x501 only the pins remained there, the xtal boddy has been removed intentionaly!
              • ricoleal
                • Oct 2012
                • 9
                • Portugal
                Re: 17MB11-6 Vestel
                Hi, fitted the original 20.000mhz xtal but stil no picture, T-con board had a burned fuse(Could be related to power supply problems, alredy corrected (caps)). Fitted fuse and everything works fine now.
                Problem solved! Thank's guys. Hope this tip helps someone
                • France_53
                  Vestel tv, how to flip the image?
                  by France_53
                  Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                  05-12-2024, 05:22 AM
                • FlailingEngineer
                  Help with Bush Tv (Vestel 17mb95m Mainboard)
                  by FlailingEngineer
                  Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                  Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                  05-31-2023, 06:52 AM
                • massimomax
                  Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                  by massimomax
                  Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                  spero che qualcuno può averlo per riprogrammare eprom. grazie
                  Post in English !!!
                  I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                  02-28-2025, 07:27 AM
                • Adenitz
                  Troubleshooting Vestel TV, has standby, but cannot turn ON
                  by Adenitz
                  I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                  Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                  Both boards are shown in the attached photos.
                  What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                  12-27-2023, 03:43 AM
                • McWhitePink
                  Help, 38.4MHz xtal has no output on MSI z690
                  by McWhitePink
                  Can anyone help me, why the board doesn't have 38.4M xtal output? Is it the XTAL dead or the PCH dead? for this reason, the board doesn't power on.
                  12-16-2023, 03:23 AM
