Samsung PN50A510
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Samsung PN50A510
    I just picked up this tv. Seems to have the powere issue that others hav posted about.
    I'm going to replace C102, which is a 10v 47uf tantalum capacitor.
    When I measure the one that is on the board, it measures 128uf.
    Why such a big difference? Is my board somehow different?
    The board number is BN94-1880A.
    On the bottom of the board there capacitor isn't labeled C102 but it's in the position that it shows in the pictures of other posts.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PN50A510
    It measures that as its on the Pcb, there is other buck capacitance for that rail connected to that cap so thats why it reads that.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Ok thanks reecey. This cap is smaller in person than the picture seemed. Lol
      Shout I buy a hot air gun or can this be accomplished with a soldering iron?
      I have a station with a variable temperature setting.
      Or should I send the board out for repair for $40?
      Lol
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I would say hot air to remove and iron to get the new one on. I would personally use an iron but if your not that confident soldering use hot air to remove it.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Also why send it out, you can do it lol ! Gain some experience step out of your boundary !
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            I'd have to buy a hot air gun. I might try with my soldering iron.
            I'll order 2 or 3 of them. I'll also go buy a heat gun, I know it's not as good as a hot air station like I know you pros have but I've see people use the 2 setting kind.
            If anything it will be good to have around.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Yeah, to get it off basically flood both pads with solder and swipe it off. Use tweezers to align and solder the new one.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                +1
                As ReeceyBurger123 says, flood it with solder and it should drop off.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Originally posted by dick_barton
                  +1
                  Yay lol
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    The cap arrived I put it in.
                    The tv doesn't turn on. The relay clicks, the front power led flashes and there are lights on the logic board that flash.
                    The new cap has different markings than the old one. It has a + on one end.
                    The old one didn't as seen in the picture. It has a gray line on one side. Was I correct in assuming that was the negative?
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      Back of the tv.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Err--So Whats this fuse you are now on about then?
                        --Thought you were on about a cap...
                        Did you not do proper fault-finding and run test-patterns on the set?
                        Tis obvious from pics--the PSU is flashing out a fault-code.....
                        TELEFIX
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          I'm sorry. I meant to say cap. Not sure why I said fuse.
                          The psu isn't flashing. The logic board below it is.
                          I did a search for the model number using the search function. The problem with the set matched what other users in the thread were experiencing. So this was the first thing I tried. The cap was cheap and I wanted to try my hand at replacing components like this.
                          It was my first attempt.
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            That PSU is a known type that causes issues. Search its BN number...
                            TELEFIX
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Thanks Alastair. I will ASAP.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Originally posted by Malachi
                                The cap arrived I put it in. The new cap has different markings than the old one. It has a + on one end.
                                Here's a guide for future reference.
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  Then I put it in backwards. So I guess I better turn it around before proceeding.
                                  Could that have ruined it? I purchased three so I can replace I if it did.
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    Reversed the cap and the tv seems to work now. Is it normal for the logic board LEDs to blink continuously?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Good news, also yes thats normal.
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        Thanks reecey. No atta boy for my first smd soldering job? I didn't throw a board at it.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          09-07-2024, 05:50 AM
