Westinghouse VR-4085DF wont power on & no lights
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    #41
    Re: Westinghouse VR-4085DF wont power on & no lights
    L6265A is the correct number and its a PFC chip.
    So what number mosfet was blown Q?
    • vinceroger69
      • Mar 2012
      • 6714
      #42
      http://pdf1.alldatasheet.com/datashe...CS/L6562A.html
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        Trying to work out which chip was driving the blown Mosfet. What IC number is on IC2.
        • vinceroger69
          • Mar 2012
          • 6714
          #44
          maybe a picture of the bottom of the board showing the area around where the blown moset is removed from will help us more to locate any other parts to check or change.
          • hackerjoe
            • May 2016
            • 25
            I realized after I removed them to test I mixed them up so I wasn't sure which was actually bad but I think it was the one closer to the diode.
            • hackerjoe
              • May 2016
              • 25
              I think the Mosfet circled in Blue was the bad one.
              • hackerjoe
                • May 2016
                • 25
                Hello everyone !
                Thanks for all your help !
                I found a power supply board for like $42 w/ shipping.
                It came today and after installing it I now have a working TV again.
                I may look around for the power mosfet and replace it and the fuse to see if it fixes the bad one or I may just hang onto it for parts.
                Thanks again everyone for your help !
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • WVUfan
                  PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                  by WVUfan
                  hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                  08-11-2025, 01:12 PM
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
