Sony KDL55EX500 Main Board Problem
  • Charlie Clemett
    • May 2016
    Hi to all this is my first Post and hoping someone can help
    First off I Run a small Shop, mainly repairing phones and the like but lots of other things as well
    But today someone has bought in the above Board. So got busy looking for the Schematics, Na! could not find them, Sony are no help.
    Anyway, this board has had a fire on it by a Poly Cap (C 6307), taking out C6308 & C6305 and also the Toroidal Inductor at L6301. It does seem to be limited to that though.
    So my Question is, What is the value of the Caps
    The Marking on the Green Caps are: 105J2W R P012 ( The 3 of them are the same )
    and the Toroidal Inductor is so heat affected that there are no indicators on it to give me any clue. Cap C6307 sits basicly hard up against it and it has copped the full force of the fire and heat and as you can imagine all have been so heat affected they can no longer be read with the meter. So if anyone can help me I will be very grateful
    Cheers
    Last edited by Charlie Clemett; 05-24-2016, 07:59 PM. Reason: mistakes needed correction
  • R_J
    • 9625
    Re: Sony KDL55EX500 Main Board Problem
    Welcome to Badcaps, What would be helpfull is if you could post good clear pictures of the board, and also the area with the problem, and if there are any other numbers on the board, someone might have a board like it and be able to help.
    Also you should have posted in the "Troubleshooting TVs and Video Sources" forum, you might get a quicker response
    Is this the board?
    The cap.value would be 1uF +/-5% 450 volt I believe those are Metallized Polypropylene Film caps
    • olomoe
      • Aug 2024
      • Deutschland
      Is this the board?
      tanks for the help with the capacitors, do you also know the values that i need to know to order a new coil. it would be nice if you let me know where to find this information as well. thanks in advance
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        Toroidal inductor on a main board? I think not..
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
