Panasonic TX-P42G10B led flashing 5 times No power up
  • london-freddie
    • May 2015
    • 472
    Hi looking at this tv for a friend its not mine,
    when power switched on relay clicks on power board, then front led flashes 5 times
    not touched anything yet but searching google seems to point to 5v on A board missing if I am reading it right
    will get some pics of boards as soon as i can after i get the back cover off
  • london-freddie
    • May 2015
    • 472
    Re: Panasonic TX-P42G10B led flashing 5 times No power up
    pics of boards
    • london-freddie
      • May 2015
      • 472
      ok back cover off noticed when i press power button on, relay on power board clicks once then one of the transformers makes a buzzing sound for about 1 second, I think it coming from the transformer certainly in that area, then red led starts its 5 flash sequence
      • Diah
        • Feb 2013
        • 6613
        5 time blinking of LED related to power section, not the main board as your photo No1 , i think there are other boards near to power boards, so please post photo for the back assembly
        • london-freddie
          • May 2015
          • 472
          just been reading on the net shop jimmy, they are linking 5 blinks to the sc board.
          first check i did was to disconect cable from sc board to power board, I have a short across connector SC2 on the sc board
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok then your S/C is shorted. Start checking the power fets and see if any are shorted.
            • london-freddie
              • May 2015
              • 472
              hi again any tips on how to check these fets on the sc board
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Well its quite easy, just like how you tested the connector. See if any devices have a dead short across them.
                • Diah
                  • Feb 2013
                  • 6613
                  Originally posted by reeceyburger123
                  well its quite easy, just like how you tested the connector. See if any devices have a dead short across them.
                  +1
                  • tw2005
                    • Oct 2011
                    • 6458
                    What sc is in this?
                    https://www.badcaps.net/forum/showth...light=Tnpa4844
                    In that thread you will find a Chinese bulletin for this board
                    • london-freddie
                      • May 2015
                      • 472
                      SC board is TNPA4844 AD
                      still not sure how to check these fets, i assume you are reffering to the fets attached to the heatsinks, 25 in total
                      3 legs on each
                      • london-freddie
                        • May 2015
                        • 472
                        SC Board TNPA4844 AD
                        • tw2005
                          • Oct 2011
                          • 6458
                          You just start probing any 2 legs for sc. You will need to remove to confirm as you will find diodes short in parallel with the igbts.
                          Unless you intend to rebuild the board there is no point if you found sc2 short.
                          You need a sc . If you want to rebuild it will be an interesting challenge
                          • tw2005
                            • Oct 2011
                            • 6458
                            Read that other thread and pdf
                            . That should narrow things a bit
                            • london-freddie
                              • May 2015
                              • 472
                              ok will have a read of it tomorrow getting late now, however probing the legs of these fets nearly all of them seem to have shorts across them, may be easier just to change the board
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                It would be unless you have a good soldering station and the time to remove the fets to test them.
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • STKR123
                                  Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                  by STKR123
                                  As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                  I wonder if re-flashing the BIOS might be of any use here.
                                  As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                  There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                  11-03-2024, 06:58 AM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
