VIZIO VX32L power supply running VX37L television
  • ZnsaneRyder
    • Oct 2015
    • 88
    • Merica
    VX37L is the tv I am repairing
    VX32L is the PARTS TV
    I was having trouble with 5V standby keeping voltage on the VX37L with the mainboard connected, so I suspected mainboard was pulling down the 5V rail. Tried Mainboard from VX32L, same symptom, so not the mainboard. Without the Mainboard plugged in, I get full 5V standby voltage.
    I connected the VX32L power supply (PSU) inside the VX37L TV, and it runs fine. I get image on screen, and backlights, and everything. I am heat-testing the power supply to see if it is capable of running the larger set.
    BOTH PSU state 3A input, but ONLY the VX37L PSU states the amperage of the individual outputs, not the PSU from the VX32L.
    Only other issue, is screw holes don't line up, but I can adapt that.
    I still trying to repair the PSU for the VX37L and cannot find the fault as of yet.......
    Is it safe to use the 32 inch PSU for the 37?
  • ZnsaneRyder
    • Oct 2015
    • 88
    • Merica
    Re: VIZIO VX32L power supply running VX37L television
    So far the heatsinks are about 100-110F but the MBR30H100CT for the 24V rail (backlight) is running 146F so it seems to be warm, but not running too hot.
    The output heatsink on the 37 inch PSU is smaller, go figure, so it seems the 32 inch PSU will run this TV?
    Any input? I'm about to put this set back together and make adaptor mounts for the PSU to bolt in.
    • SLK001
      • May 2014
      • 264
      Believe me, if the manufacturer thought that he could run the 37" TV off the 32" power supply, he would have done it.
      Best to get the properly sized power supply.
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        From the checks already carried out it appears as thought he original psu is at fault.
        I would check the caps on the psu for high ESR or change in capacitance value.
        They can all look good but that is no guarentee that they are.
        • ZnsaneRyder
          • Oct 2015
          • 88
          • Merica
          Thanks, all the caps check good, I will keep checking.
          I feel silly for starting the thread, without better comparing the two units first. For some reason, the 32 inch power supply uses a higher rated mosfet, diode, larger transformer, slightly more heatsinking, and more caps? WTF? This makes it obvious that the 32 inch is actually the better supply. Both are rated same input draw from the wall as well.
          WTF, why would Visio use a better PSU in the 32 inch? Maybe they were cutting costs in later, lesser selling models?
          Regardless, I will use the 32 inch supply. I added an extra 1000uf 35V cap, and put a healthy amount of thermal compound on the plates that bolt to the heatsinks, and that made it run somewhat cooler. I will do some temp checks when it warms up again.
          • ZnsaneRyder
            • Oct 2015
            • 88
            • Merica
            (On the broken 37inch supply) I am only getting 170V on the Main Cap after the PFC. The PS does not turn on, so the PFC doesn't rise. Even though I am using the 32 inch supply, I am still trying to repair the 37 inch psu. Something in the 24/12v section may be bad, but I haven't found it yet.
            • ZnsaneRyder
              • Oct 2015
              • 88
              • Merica
              Hottest part, the 30H100, now runs only 134F, quite a difference after adding the thermal compound to the heat sink plates!
              • Garret Matt.
                VIZIO (V555-H1) Television with odd cascading display fault
                by Garret Matt.
                I'm working on a Vizio Model V555-H1 that displays a cascading series of horizontal lines when first powering on. These lines appear to be in the shape of the Vizio Logo and descend until reaching the logo before resetting to the top and continuing their descent. I have reseated my TCON board and dusted connections but still have this fault displaying. I'm familiar with vertical lines but this one is a new one for me. My research into this problem hasn't yielded results as keyword searches point back to vertical line problems.
                Anyone have any recommendations? I...
                04-04-2025, 02:56 PM
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
