TC-P50UT50 3 fast blinks
  • TvSmartParts
    • May 2016
    I have been doing tv repairs for about a year and a half or so. already repaired a couple hundred tvs and i have never came across this issue before...
    so my UT50 was giving me 8 blinks so i tested the SS and fount bad components and found some bad. i repaired the board and it worked perfect for about 6 hours and then shut off and gave 3 fast blinks. i opened it back up and reseated all the wiring and tested the SS for shorts and its good to go. still 3 fast blinks.
    i checked on line and founf that 3 blinks could be the D board. I have no clue what board the D board is on this tv.
    any information will help.
  • marekk
    • Mar 2013
    • 36
    Re: TC-P50UT50 3 fast blinks
    I had ones such problem and it was Main AV board,
    • tw2005
      • Oct 2011
      • 6458
      i checked on line and found that 3 blinks could be the D board. I have no clue what board the D board is on this tv.
      Except there is no D board in which whatever you're reading is most likely for another older generation TV.
      Looking at this guide it sounds like Marekk could be right.
      There's a couple of fault trees, one at plug in, the other at turn on plus you want to follow the UT50 one.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • huj3r
        Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
        by huj3r
        Hi there!
        I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
        Photo of the situation after the black shadow dissipates:
        After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
        I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
        > This indicates HFR Communication error. [ HFR Communication...
        08-15-2023, 10:55 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
