Hi I have an issue with this models PSU unit, a month ago all of a sudden something popped while watching tv and a circuit breaker switch triggered. Took it to a repair shop and they diagnosed a burned PSU unit, replaced transistors and it worked for some month or so. It shut down in the meantime few times, with 5 led flashes and a loud pop was heard again. Took off the PSU board and they replaced some more components (transistors and a popped capacitor ) after installing the board back in the tv everything worked fine for couple of days and it popped again and circuit breaker is triggered. Tv is connected to a power through voltage regulator that maintains a steady voltage I was thinking to prevent a second malfunction of power board but obviously it didn't help.
Since tv is huge cant afford to rent a truck every few weeks just to carry it to a repair shop and back, but was thinking to order a new PSU board and replace it.
Can someone suggest if the problem is solely within the PSU or it is caused by a short in some other board? Dont wanna burn the new PSU board .
Also when the tv was working all the voltages were within specified values. *(label on the plasma screen).
