What to do with a 60" LG... (60PG3000)
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Couple of days ago, a 60" LG set came into work. It was put by side of the scrap TV skip as the skip was full.
    It just so happens, --That day is my day off.
    Next morning they changed the skip--but didn't move the 60 resting against it.
    --The obvious happens--it gets smashed.
    But--Only the outer glass and front cabinet suffered, Panel is OK--at least unbroken. One of the guys working on the site was told by feller who brought it in that its been checked by so-called, 'tv-engineer' and is completely buggered.
    For a larf, I trundled it down to the workshop on my trolley and checked it out. It has a Y-SUS short,--the SUS_Up and SUS_Dn trios of IGBTs are short.
    It'll cost maybe £20 in IGBT's or a fiver for a complete Y-SUS from fleagay.
    Gotta try it out--but have no idea just What to do with it after. Cabinet is wrecked and so is the front glass, so cant sell it if it does work with new board...
    Another thing against it--Only 720p
    TELEFIX
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: What to do with a 60" LG... (60PG3000)
    Hope it goes well, btw the panels in these are junk so dont expect it to be working with out lines on it lol
    • comptek
      • Aug 2013
      • 606
      i got the 50" version fixed it and got a line smack bang in the middle
      • comptek
        • Aug 2013
        • 606
        hmmm heated the lower buffer flex to screen its now gone.............. for now
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Hmm probably the Cof Ic has a bad connection would say tab bond fix it but the Ic will over heat lol. Also yours was a PS3000 which is FHD ?
          • comptek
            • Aug 2013
            • 606
            youre right reece 1080
            it was done on the edge of the screen its been on for whilw aint come back but im sure it will
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Lol maybe try, taking the panel down and putting some thermal pads to push against thw Ic ? Like a tabbond repair but thermally
              • Diah
                • Feb 2013
                • 6614
                i used always ACF Anisotropic conductive film .. easy to replace any flex on LCD within 1 hours at most.. i think you need to try it.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Cheers Diah, might give it a shot and order some
                  • Diah
                    • Feb 2013
                    • 6614
                    however 150m long are round 150 USD but they worth allot, just keep the roll at Temperature -5 to -10 degree
                    • comptek
                      • Aug 2013
                      • 606
                      i have just put it together lolol, its not the chip side though i heated up the glass side the chip has transfer tape to the chasis and then the long metel plate that runs along the bottom
                      • PlasMatt
                        LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                        by PlasMatt
                        I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                        09-20-2025, 06:50 PM
                      • Salvatore057
                        plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                        by Salvatore057
                        I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                        Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                        I am lost, should I change the YSUS board? Is the YSUS board damaging...
                        04-29-2018, 01:29 PM
                      • legg
                        LG 42PC3 buffer output doesn't follow YSUS
                        by legg
                        LG42PC3D -UD originally with green lamp but no display or audio.
                        Owner says was working, then went 'pop'.
                        All 5V caps bulging. replaced.
                        All PSU output voltages within spec but -Vy is low on YSUS.
                        One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                        eventually shorts DG. Replaced all 3 - -Vy now OK.
                        Y scan buffer test point does not follow YSUS output below -50V
                        Note: This unit seems to expect YSUS output to park at -Vy in between
                        drive signal pattern periods. A replacement drive signal board confirms this....
                        11-18-2021, 11:49 AM
                      • Truncatedhose
                        Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                        by Truncatedhose
                        Greetings all!
                        Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                        Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                        07-04-2018, 10:59 AM
                      • zwarder
                        eax61319402 50PJ350 YSUS
                        by zwarder
                        Hi
                        Had shorted YSUS
                        Q24 RPJ63F3
                        C726 cap
                        Q11 K3667
                        R528 & R529 2.2 ohm
                        replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
                        ZSUS is also good as far as I can tell
                        Anyone could help me out on this one
                        10-23-2023, 08:11 AM
