pn50b450b1d No Power
  • Hiatsu2k8
    • May 2016
    • 25
    Hi and thanks for looking!
    I believe I've determined the problem but wanted to run it by you guys to see if I'm correct.
    I have a pn50b450b1d that doesn't turn on. It's the classic clicking issue that a lot of plasmas have. I will upload images but there are no visably damaged capacitors. VA should be 55 and vs should be 209. When I plug in I get nothing close to those to values. A small spike and then nothing. When I unplug both the X and Y board from main I get the correct values immediately at power on but then they slow drop off to 0. I tried checking the values on the X and Y board themselves but nothing is correct. I removed the power board and used an ESR meter to start checking capacitors. It's the blue esr meter I built and calibrated it myself and it works well. Some of the capacitors have much higher readings then they should. I'm assuming that the power board is bad. Is there anything else I should do to make sure?
    Thanks!
  • Hamie
    • Apr 2014
    • 1383
    Re: pn50b450b1d No Power
    Your power supply is probably OK.
    The voltages only come up briefly on this model if you have the x and y unplugged.
    • Hamie
      • Apr 2014
      • 1383
      On the y-sustain look at the input from the power supply and see if the vs pin is shorted to ground.
      • Hiatsu2k8
        • May 2016
        • 25
        Pin 5 and 6 are both VS, I'm assuming the black wire is the ground. Is that what you mean by short to ground?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Probably IGBT's on the Y-SUS S/C. Very rarely caps on PSU with this series.
          TELEFIX
          • Hiatsu2k8
            • May 2016
            • 25
            What are igbt? I'm interested in learning how to isolate the problem. I should have all the tools to diagnose. Thanks
            • Hamie
              • Apr 2014
              • 1383
              Upload a photo of the top and bottom side of the y-sus.
              Did you confirm that vs input is shorted to ground?
              • Hiatsu2k8
                • May 2016
                • 25
                No, I did not. I apologize, I'm not familiar with how to do that. If you could please explain I'm sure I will catch on quick though. The pictures are attached.
                • Hiatsu2k8
                  • May 2016
                  • 25
                  By using a multimeter in ohms mode test both VS pins 5 and 6 and it read 0000. No short to ground, is that correct?
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Reads 000 then short, read OL = open.
                    Should equip yourself with at least a bit of knowledge of how to use your own multimeter before delving into a complicated and potentially lethal machine like a TV Set!!
                    Sorry, but--I'm Out!
                    TELEFIX
                    • Hiatsu2k8
                      • May 2016
                      • 25
                      I'm trying to learn, that's why I'm here. The VS input is shorted to ground. Is there anything else you can help me with?
                      • mmartell
                        • Oct 2013
                        • 3189
                        With multimeter in ohms mode put one probe on pin 5 OR 6 and the other probe on one of the screws holding down the board (ground) Make sure the tv is OFF. What is the measurement ?
                        • Hiatsu2k8
                          • May 2016
                          • 25
                          Thanks for your help. With one probe on either pin 5 or 6 and the other probe on a ground screw I get OL.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Redo the test using the OUTER pins one at a time with a ground screw then test each pin together. So three tests, report back.
                            • Hiatsu2k8
                              • May 2016
                              • 25
                              Hi, so I was confused, you said three tests but to test each pin together. Is it possible to explain what I should be getting and why? I wanted to be thorough so I tested EACH pin together and here are my results:
                              To Ground;
                              Pin 1: 20< (the reading kept increasing starting below 10 so I stopped after 20
                              Pin 2: 1.8
                              Pin 3: 13.23
                              Pin 4: 1.9
                              Pin 5: OL
                              Pin 6: OL
                              To Each Pin:
                              Pins Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6
                              Pin 1 x 21.81 0.719 0.7 OL OL
                              Pin 2 x x 12.22 0 OL OL
                              Pin 3 x x x 12.58 OL OL
                              Pin 4 x x x x OL OL
                              Pin 5 x x x x x 0
                              Pin 6 x x x x x x
                              In case the table doesn't come through I also attached the xls file. Thanks again for your help.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Oi my mistake here. That test is useless if the fuse is blown. One meter probe to ground the other probe on the far side of the fuse. If you're not sure which side I'm talking about try them both. I'm betting you will have a very low resistance reading on one of them.
                                • Hiatsu2k8
                                  • May 2016
                                  • 25
                                  I don't see a fuse on this board.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Does your meter have a "Continuity" mode ? You don't want any beeps between a power source and ground because that means you have a short circuit = bad. By what you're reporting here you don't have a short on VS on the Y board but your Va line is suspect. Remove the connector from the X board and check for a short there.
                                    You need to do a little reading I think to get yourself familiarized with some of the working concepts here.
                                    • Hiatsu2k8
                                      • May 2016
                                      • 25
                                      You're right I definitely do. I'm having a hard time wrapping my head around some concepts though. If you're not out of patience yet I think I figured it out. For instance I tested the vs on the x board and it did beep. This would indicate a short or no resistance or short Circuit which might be why the tv isn't turning on to prevent a dangerous situation. However on VA on the y board there is no beep but also no resistance. Could that indicate an open Circuit on that board?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        It could but it's not important at the moment. If you leave the X board unplugged and plug the Y board back in does the tv start normally ?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          Today, 05:52 PM
                                          09-06-2024, 05:59 AM
