LG47LN578 Backlight high intensity opening logo
  • satinser
    • Oct 2012
    • 214
    After repairing a number of this model with LEDs failed in back light array. It is noticeable how bright the LEDs are for a few seconds (opening LG logo screen) when first switched on before gradually dimming down to back light setting in menu. It is widely acknowledged that by decreasing the backlight setting to as low as possible decreases the likelihood of LED failure. The problem is that this self advertising opening logo feature cant be turned down and operates the LEDs at maximum intensity for a few second burst every time the TV is switched on regardless of backlight setting. Have tried to gain access to service menu to see if option available to cancel opening logo screen but the usual simultaneous pressing of OK on TV and remote doesn't work. Any body confirm that the service remote LG 105201M is needed and also if there is an option to disable opening logo feature in the service mode of LN series.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG47LN578 Backlight high intensity opening logo
    In my experience most led TVs start at full brightness then dim to the user settings.
    It's usually prolonged heat that kills the leds so a quick burst at full brightness for a second or two shouldn't really matter.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by hamie
      in my experience most led tvs start at full brightness then dim to the user settings.
      +1
      • satinser
        • Oct 2012
        • 214
        Thanks for your comments but do you know if there is an option in the service menu to disable LG opening logo? Also is the LG 105201M remote needed to gain access to the service menu as pressing OK on both TV and remote simultaneously dont work.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          It should be fine, also I dont think there is tbh sorry.
          • Diah
            • Feb 2013
            • 6614
            which service menu you where in, IN_START or AZ_ADJ ? logo start can be disabled.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Actually Diah is correct ! You can trun the Logo off but it still does start with full brightness on the Leds but dims after a few seconds still.
              • Diah
                • Feb 2013
                • 6614
                ReeceyBurger123 correct too... but Logo post are posted from the Main Board as we do know, and the service menu are saved at it too, when logo post disabled that correct will not effect on the first step of lighting the backlight LEDs, but at same option of service menu AZ_ADJ there were default ECO Backlight setting at 80%, this setting can be reduce to 40%, the start up post will be at this level. its Dig currents settings. then leave the LOGO on and reduce the ECO
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Thanks for the info Diah
                  • satinser
                    • Oct 2012
                    • 214
                    Many thanks again for both your comments. I think it makes sense if your going to reduce the general backlight setting to minimise future problems to also reduce the opening screen intensity. From your comments Diah its good news that thats possible. Be grateful if you could advise whether the LG service remote is needed in order to make these adjustments in the service menu. I have been unable to access the service menu in this LN series by the the usual pressing OK button on both remote and Manual controls together. Look forward to your reply.
                    • Diah
                      • Feb 2013
                      • 6614
                      the best way to inter LG service menu with Android apk which it can be used at any android mobile had IR sender such as Galaxy S5 after install choice LG and there you will find IN_START / EZ_ADJ- and IN_STOP so you need to put the pass code of LG service menu which are 0413 or 0000 ... or to do it ur self, use wave file on PC and play them with WINAMP program, the out put of the PC headphone connected to any Double IR RC,
                      take look here and download them from my post https://www.badcaps.net/forum/showpo...8&postcount=19
                      • satinser
                        • Oct 2012
                        • 214
                        Many thanks for the information and Link and taking the time to explain.
                        • Teban1306
                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                          by Teban1306
                          Hello everyone!
                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                          System Information:
                          • Model: Lenovo ThinkPad T14 Gen 1
                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                          • Current BIOS: N2XET42W (1.33) - Latest version
                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                          What I'm trying to achieve:
                          Replace the default "LENOVO" boot logo with a custom image during POST.
                          🔧 What I've tried:
                          09-14-2025, 11:49 AM
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • Verlengsnoer
                          Bios splash/logo change
                          by Verlengsnoer
                          at firs, i hope this is the right place to post my question.
                          Im looking for a tool to change the bios logo.
                          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                          i know that HP has a build in option to change the splash logo.
                          but i want to change the manufacturer logo to an own logo.
                          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                          10-28-2022, 09:52 AM
                        • conghuyms
                          MacBook Air A2179 stuck logo , pls help me !
                          by conghuyms
                          Hey everyone,
                          I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                          When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                          I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                          11-05-2025, 08:30 AM
