After repairing a number of this model with LEDs failed in back light array. It is noticeable how bright the LEDs are for a few seconds (opening LG logo screen) when first switched on before gradually dimming down to back light setting in menu. It is widely acknowledged that by decreasing the backlight setting to as low as possible decreases the likelihood of LED failure. The problem is that this self advertising opening logo feature cant be turned down and operates the LEDs at maximum intensity for a few second burst every time the TV is switched on regardless of backlight setting. Have tried to gain access to service menu to see if option available to cancel opening logo screen but the usual simultaneous pressing of OK on TV and remote doesn't work. Any body confirm that the service remote LG 105201M is needed and also if there is an option to disable opening logo feature in the service mode of LN series.
LG47LN578 Backlight high intensity opening logo
Re: LG47LN578 Backlight high intensity opening logo
In my experience most led TVs start at full brightness then dim to the user settings.
It's usually prolonged heat that kills the leds so a quick burst at full brightness for a second or two shouldn't really matter. -
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Thanks for your comments but do you know if there is an option in the service menu to disable LG opening logo? Also is the LG 105201M remote needed to gain access to the service menu as pressing OK on both TV and remote simultaneously dont work.Comment
It should be fine, also I dont think there is tbh sorry.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
which service menu you where in, IN_START or AZ_ADJ ? logo start can be disabled.Comment
Actually Diah is correct ! You can trun the Logo off but it still does start with full brightness on the Leds but dims after a few seconds still.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
ReeceyBurger123 correct too... but Logo post are posted from the Main Board as we do know, and the service menu are saved at it too, when logo post disabled that correct will not effect on the first step of lighting the backlight LEDs, but at same option of service menu AZ_ADJ there were default ECO Backlight setting at 80%, this setting can be reduce to 40%, the start up post will be at this level. its Dig currents settings. then leave the LOGO on and reduce the ECOComment
Thanks for the info DiahPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
option of service menu AZ_ADJ there were default ECO Backlight setting at 80%, this setting can be reduce to 40%, the start up post will be at this level. its Dig currents settings. then leave the LOGO on and reduce the ECOLast edited by satinser; 05-11-2016, 06:48 PM.Comment
the best way to inter LG service menu with Android apk which it can be used at any android mobile had IR sender such as Galaxy S5 after install choice LG and there you will find IN_START / EZ_ADJ- and IN_STOP so you need to put the pass code of LG service menu which are 0413 or 0000 ... or to do it ur self, use wave file on PC and play them with WINAMP program, the out put of the PC headphone connected to any Double IR RC,
take look here and download them from my post https://www.badcaps.net/forum/showpo...8&postcount=19Last edited by Diah; 05-12-2016, 01:55 AM.Comment
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by sam_sam_samI have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
I tested the battery cells there are installed right now and they are testing good with no issues that I... - Loading...
