LG 32LE5400 mainboard or panel?
  • mu2
    • Oct 2009
    • 217
    I've got an LG 32LE5400 that originally had no video displayed.
    Selecting the menu option showed some change in the what was shown on the screen but nothing legible was visible.
    The full number is 32LE5400-UC.AUSWLNR and the panel is LC320EUH (SC) (A1).
    I do not see any seperate tcon on this set - looks like the lvds cables go from the main board directly to the panel.
    There is a chip getting extremely hot on the main board - MAX17113ETL
    Chip is available from Digikey, but due to the package style I found it too difficult to replace.
    I finally found an exact replacement main board on Ebay. I ordered it and on installation still did not get any video.
    I've included some photos showing the screen with the replacement main board installed, each of the two lvds cables being disconnected and shots of the rear of the set.
    The replacement main board doesn't seem to have any chips getting hot.
    So the question is - did I get another faulty main board or is the panel bad?
    Any input is appreciated.
    Thanks,
    Mike
  • mu2
    • Oct 2009
    • 217
    Re: LG 32LE5400 mainboard or panel?
    I'm resurrecting this post that I made some time ago. Never got any responses.
    Anyone have any input on this problem?
    Does this look like a panel problem or is this bad video driver on the main board?
    Thanks,
    Mike
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Try inputting a signal via any of the connectors eg. from the HDMI or USB and see if you get a clear half picture with only one of the connections from Tcon to Panel.
      • mu2
        • Oct 2009
        • 217
        Dick,
        I just tried the set with video and audio into the AV1 input. I have audio but no video. I just get random vertical lines that doesn't seem to change if the video changes.
        I think that there is no t-con board in this set.
        If I disconnect the lvds cables from the main board to the driver board that's connected to the panel I get no video - regardless of which side I disconnect.
        Mike
        • mu2
          • Oct 2009
          • 217
          Finally took the tv apart down to the panel. Both the chip on film ic's are extremely hot.
          I guess the panel or both chips are bad.
          The bottom line is I have parts available to sell if anyone can use them.
          I'm pretty sure the replacement main board I purchased is good but really have no way to test it.
          Message me privately and we can discuss things.
          Mike
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I would say panel on this sorry. Its bloody hard to say though when the Tv isnt in front of you.
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
            • JDC
              (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
              by JDC
              ONN 100012588
              Issue: No Power, Then Rebooting After Main Board Change
              Short answer: replace main board and power board
              Technical answer: replace main board and Q306 & Q307 on power board.
              Long answer:
              TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
              07-15-2022, 07:39 AM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
