Can anyone help me with a schematic for the power supply for a vizio E320-a1 or info on how to troubleshoot this problem. It does not have 5v and the 12v is reading 2.8v. thanks
vizio E320-a1 no power
Re: vizio E320-a1 no power
You can start with this:
https://www.badcaps.net/forum/showthread.php?t=39740
We have no idea which version of the TV, version of the boards you have so we need to see the pictures of YOUR boards.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Can we see the pictures of the whole back side of the TV so we can see all the boards?
There are many versions of this TV models as you can see here:
http://www.shopjimmy.com/catalogsear...=vizio+E320-a1
Your version uses this power suppl board:
http://www.shopjimmy.com/vizio-adtvc...or-e320-a1.htmNever stop learning
http://www.shopjimmy.com/vizio-adtvc...r-e320-a1.htm#
So if you do not have other boards connected to the power supply board, what dcv do you get on the connector? We need to find out if something is loading down the power supply or not.Never stop learning
the voltages i get are with no connections to the power supply. Some background, we recently had a thunderstorm and i lost 3 tvs,2 routers,a modem, and stereo system. i thought i would start here to salvage what i can.
do i need to plug the connectors back in and re read the dcv?Comment
If you tested the power supply board without the main board connected then you should have the 12V (this is an always on 12V). The 5.2V is generated by the Buck converter IC9351 that steps down the 12V to make 5.2V.
The power supply board is on $17 from SJ so it will be more practical to replace the power supply board first.Last edited by budm; 05-09-2016, 11:03 AM.Never stop learning
Do you know the history of the TV? Was it hit by surge or lighting?Never stop learning
That means there is a chance that the Main board especially around the HDMI circuits are damaged too. You need to do real close visual inspection.Never stop learning
Assuming...7 Photos -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
