Emerson TV Buzzing-Won't turn on LF391EM4F
  • Shane711
    • 493
    Re: Emerson TV Buzzing-Won't turn on LF391EM4F
    No luck so far. Changed all the caps and didn't make a difference. I have ordered some RT8293AL and the main IC MSD8200DS-S1. Coming from China so it will be 2 to 3 weeks. I am determined to figure this out because so many of these boards are going bad. I can fix it, yes?
    I currently have 5 bad main boards with the same problem
    I will post all my progress as I come along.
    • CapLeaker
      Leaking Member
      • 8328
      Holy crap... 5 boards doing the same thing? Geez...
      Well I hope you figure it out...
      Now since you have a few of them bad ones doing the same thing, take that IC off we talked about earlier and see if that short clears.
      • Shane711
        • 493
        There is no longer a short on the board. I found a bridged solder joint and fixed it.
        Take the IC off? How about taking them all off because that is just what I did and with NO results.
        Well when I blocked off pins 1, 2 ,3, & 4. I believe these are the 12v. The buzzing stopped so it is on that line somewhere.
        I removed 1 IC at a time and tested the board. I did Not replace any ICs, I just left them off. IC3604, IC3605, IC3603, & IC3006 EEPROM. No change. Then I decided to remove the audio IC3801 but no change. So I thought it has got to be the main IC3001 MSD8200DS-S1 but no, it was not. Now I have all the major ICs removed and the buzzing is still there. Really? Like are you serious? So now I am thinking is is something so simple and I do believe it is worth it to remove every single component on this board to find out which one is bad because I will know and everyone else will know how to fix this problem.
        • Shane711
          • 493
          Is there a way to test a voltage regulator when it is removed from the board?
          • CapLeaker
            Leaking Member
            • 8328
            Did you follow the 21V from page 52 back to page 48? IC3201 and Q3282 (this one may not be installed)? All around these IC's that are on the 21V line there are chip caps to GND that could fail, zener diodes, other transistors...
            • capwizard
              • Jun 2016
              • 1991
              @Shane711
              What's the resistance between AMP+13v* to GND**?
              Mine is about 8.4 Ohm(not dead-short),after removed Amp IC and two down converters IC*** still the same... 8.4Ohm! Is there any luck?
              * CN3602 pin 6,7,8,9.
              **CN3602 pin 10,11,12,13,14,15.
              ***IC3605 & IC3604
              • Shane711
                • 493
                I took a break on that TV but I plan to get back to it. It seems there is a very small component causing all the trouble. I think I am going to do what CapLeaker suggested in post #8 and that was to put power to it and see what part warms up and that may be the bad part.
                • capwizard
                  • Jun 2016
                  • 1991
                  Good news for your 5 Emerson TVs and Mother Earth! .....Will cost you almost nothing to repair!
                  After I removed Amp IC and two down-converters IC3605 & IC3604. Mother board still has short. So, I cut two traces of PCB to isolate the problem. found the low resistance 8.4ohm was caused by..................A SMD cap 4.7uf C3637...................I put all the parts back, but omitting the C3637 cap. The Emerson TV works beautifully.
                  [Tech Tips] Simply remove the SMD cap C3637 4.7uf.
                  • CapLeaker
                    Leaking Member
                    • 8328
                    so I wasn't far off then. congrats! Nice pics btw.
                    • Shane711
                      • 493
                      What? That is totally awesome. I got to test that out. Do you know how many TVs will never hit the dump because of this? This is so awesome. I will let everyone know as soon as I get around to it.
                      • capwizard
                        • Jun 2016
                        • 1991
                        @CapLeaker Thanks for all hints but I'm too much of a coward to use external power supply to do an injection (Because of a bad past experience.). It will save a lot of time.
                        Seems it is a common problems of this kind of TV .
                        Another victim:
                        citywidetvtech Emerson LF401EM5
                        Was making a chirping beeping sound when trying to power on. AMP+13V Line shorted to ground. C3637 just below the black ribbon connector on main board is shorted.
                        BA4GU5G0201 3 main board.
                        • CapLeaker
                          Leaking Member
                          • 8328
                          Another victim:
                          There are other ways of finding a short on a main board too. Not everyone has a Leakseeker 89
                          • capwizard
                            • Jun 2016
                            • 1991
                            I do have A CapAnalyzer 88A(Paid $180),can I use as a Leakseeker 89 ?
                            • Shane711
                              • 493
                              That EDS-88A is a nice tester, better than what I have. I like it. I can't find any for sale, maybe there is a newer version out there. I guess I will have to find a used one.
                              • capwizard
                                • Jun 2016
                                • 1991
                                The best ESR meter for me, is In-circuit capacitor ESR meter made by Creative Electronics, Yes... Made in USA
                                • CapLeaker
                                  Leaking Member
                                  • 8328
                                  Nope.
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    A ESR meter is 1k or 100k HZ signal generator + low Ohm meter
                                    What do you think, If I put a capacitor to filter out the signal from test lids or change to dc voltage, then read out the value of resistance bridge. Thank you.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      Bad news for Mother Earth! my 3 Emerson tvs- complicated tv set- have all different problems.
                                      I fixed two more LF391EM4F . One tv has 3.3v standby. Mainboard has all voltages present , changed EEprom fix the problem.
                                      Other one has no standby 3.3v, but flex cable from power supply has 3.3v (pin 8 AL+3.3V).
                                      cn3601 pin 8 is 3.5 ohm then Trace to IC3601 AP1117EG-13(+2.5v REG) pin 2 is 0.2 ohm(shorted to MSD8200DS-S1).
                                      Took out processor IC3001 then everything's Okay. Need to order MSD8200DS-S1 .
                                      • warriorx1x
                                        • Mar 2023
                                        • Mexico
                                        #39
                                        Looking for dump for:
                                        Emerson LF391EM4F
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
