Panasonic TC-P50G20 Random Static
  • mfucilli
    • Mar 2016
    • 10
    Recently replaced my panels TXN/A1MGUUS (TNPH0834AE) A Board, as it was causing a 10 blink error and wouldn't power on. Replacement had the unit working fine for a few weeks now.
    Within the past two days I've been noticing quick blips of static showing up on the screen. Happens very quickly and only noticed it three times so far. I have a Denon receiver hooked up to HDMI 1, and using a PS4, DVD, and Chromecast (all plugged into 3 inputs on the reciever). These flashes happened twice on the PS4 and once on the Chromecast. I haven't used the DVD in a while.
    I'm thinking perhaps a bad HDMI cable, or is the new A Board faulty?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G20 Random Static
    Maybe try recording the screen to capture this and post a still image if you can.
    Is it like digital noise, like blocks?
    or look anything like this?
    These boards can have issues as they age or with heat end up with bad solders under the BGA chips I suspect.
    I've had one generate random lines as pictured fickering and as the board heated got worse.
    So it may be a sign of trouble, would need to see what it is if possible.
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • Dannyx
      Panasonic PBX shuts off at random
      by Dannyx
      Good day folks. I wasn't too sure whether I should start this discussion just yet, because I feel I haven't dug deep enough, which I can't do until Monday at work, but I eventually thought I'd just go for it so by the time people start joining in, I'll hopefully be able to complete my measurements.
      TL;DR - Panasonic KX-NS500 PBX sometimes dies - PSU issue (schematic attached). 41v rail drops to 25v and 15v rail goes off entirely. Often, even a power cycle doesn't restore it - main cap (C4) needs to be "manually" discharged for it go gain.
      Details: to keep...
      03-12-2022, 05:03 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • Leebo249
      SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
      by Leebo249
      Hey,
      A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
      Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
      Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
      09-07-2025, 07:23 AM
    • AquaMan Ua
      Problem with PANASONIC CF53 laptop after changing BIOS settings
      by AquaMan Ua
      Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
      05-17-2025, 09:40 AM
