LG 50ps3000 power fault
    Hi guys
    I'm currently looking into a power fault, where when the main board is connected the dc relays don't hold in and power to the rest of the TV fails.
    When I disconnect the main board the power Is distributed around the TV (I think In my basic knowledge) as normal.
    Would I be correct in replacing the main board or could there be more to it than that?
    Many thanks
    Re: LG 50ps3000 power fault
    The power supply won't power on without the mainboard.
    You'd need to jump it on.
    Run test patterns with the mainboard disconnected.
      Try to disconnect the both PCBs: ZSUS Board (Right Side) and YSUS Board (Left Side). If You Power on now, and the Relais is still holding, than you know that the Fault is somewhere there. Measure tzhe Voltages on the Connectors, explicit VS and VA. They should be there if the Power Board work properly.
        Thank you.. But I think u misunderstood?
        It's only when the main board is connected that the power shuts down, I think maybe due to an overheat cut out because I can't then power up at all until some time has passed.
        When the main board is disconnected the power on the board is fine, 5vdc to all points and relays hold in..
          How can I jump the board please?
            Can you help me powering up the TV with the mainboard connected and running the test please
            Many thanks
              As long as the main board is disconnected everything else connected will power up.. Apart from the screen. But the Voltages travel to the other boards.
                So I disconnected everything from the power board, switched the power on, and u can here the relays kick in and then drop out.
                Connected everything except the main board, switched it on and again they click and then drop out, as above.
                Then I disconnected everything, connect the the main board, switch on, and nothing happens.
                Now even when the main board disconnected nothing will happen even with the relays until about 10 minutes has passed..
                  Hmm--
                  WHICH board are you Calling the 'Mainboard'....?
                  Set WONT Power-On WITHOUT the (Real) mainboard connected!
                  Real mainboard has Antenna socket and all the other inputs on it....
                  TELEFIX
                    Originally posted by Alastair E View Post
                    Hmm--
                    Hi Alistair, the 'main board' I'm referring to is the board with the hdmi/scart etc on it...
                      OK--And you reckon the set is powering up--without it?
                      --It Shouldn't as far as I know....
                      TELEFIX
                        When the y sus is connected the relays stay in,
                        I'm getting readings from the bridge rectifiers. Theres 5vdc on the pins to the YSUS ... Leds flashing on the ctrl(?) board.
                        Once I take out the YSUS, the relays drop and everything dies.
                        But regardless of what is plugged into the power board, as soon as the main board is connected, everything dies, and won't come back on until about 10 minutes after the main board has been disconnected...
                          Power board fault maybe??
                            Anybody??
                              So with Ysus unplug you get Vsus voltage ?
                                With YSUS and ZSUS unplugged it's not holding on. With the left board plugged in only (YSUS) I was getting 196vdc. With the right board (ZSUS?) plugged in only it was giving me same 196vdc at first but now it isn't and the relays aren't holding in.... So I plugged in the main board and it all tripped out
                                  Is anyone making sense of this problem?? I would love to get to the bottom of it but I'm out of my depth here....
                                    can i ask a few questions.....
                                    when everything is plugged in do you get the red standby light?
                                    when you press power on/standby button does nothing happen(red light doesnt change state)?
                                    sounds similar to an issue i had with my old philips BDS42V, it turned out to be a Voltage regulator on the standby line..... When i unplugged the connector that fed back the to the stanby line, my Plasma would power up, but obviously no signals from mainboard......
                                    Not sure what the voltages were exactly but i remember that input voltage was 5v and output was 1.2 or something like that... when i replaced it the voltage on the output came back up to 1.8v as far as i can remember, this may not be your issue but your initial post is a little confusing.....
                                      Thanks for responding Steve.
                                      No standby light comes on at all when everything is connected.
                                      Basically when the main board is connected it's like an overheat devise is triggered but I can't see where that is, and then basically the TV will not do anything for approximately 10 after the main board has been unplugged (I'm assuming the overheat is cooling)..
                                      Hope that helps
                                      My number is 07506690823 if anyone can talk me through some trouble shooting.
                                        can you get some pictures of the boards.... then some pictures of the connectors... freferably showing the pin values... maybe there is a legend for them near to the connectors.... If you have no standby/power light at all then i would assume that something on the powerboard has failed..... so that is the first place i would look and check where all the voltages are.... Once we have pictures we can ask you to take readings from for specific pins and work out from there.... i am happy to call you and talk you through the things i would do but i cant without a visual representation of what i/you are seeing first...
