VIZIO E550i-B2 Sound - No Video Problem
  • ckramer
    • May 2021
    • 4
    • Inited states
    #61
    Re: VIZIO E550i-B2 Sound - No Video Problem
    Thinking we had an LED backlight issue, we removed the back panel to find a burned spot on one end of the pin plug connecting the power supply board to the LED board. (The burn spot is on the power supply board side) Is this our issue with the whole TV being dim but having sound?
    • SLK001
      • May 2014
      • 264
      This TV doesn't shut down due to a backlight fault, so you can have both video and audio with no backlight. The black spot was due to the intermittent sparking of the remaining connections.
      Your fix should be the one detailed in post #49. The way I would do it now, would be to alternate between top and bottom connection. If you use 22 gauge solid insulated wire, having four on each net will supply more than enough current. There is no need for the entire 8+8 that I used.
      As for the fix in post #49, it was still going strong when I took the TV out of service in early March of this year.
      • ckramer
        • May 2021
        • 4
        • Inited states
        #63
        Thank you for taking the time to help with my issue. I looked at post #49. Please know that I am a female but I pride myself on watching fix-it videos and have saved myself tons over the years fixing my washer, dishwasher, etc. I'm determined to give this a shot as well.
        I did fail to include a picture. I've attached one here. So replacing the whole power supply board is not necessary?
        • SLK001
          • May 2014
          • 264
          Your picture doesn't show anything other than the black area. Take an extreme closeup of the BACKSIDE of the connector (the solder joints), like those shown in post #1. Only this type of picture will tell the tale.
          • ckramer
            • May 2021
            • 4
            • Inited states
            #65
            My sad attempt at soldering! I did this, put it back together, plugged it in and it actually worked for about 30 minutes. Then it returned to the dim screen with sound.
            • SLK001
              • May 2014
              • 264
              You have to do them ALL. Looking at your picture, I can see that every one of the joints are broken. You need to do the fix in post #49. If you don't, your fix will just fail again in a couple of months.
              As for your solder blob, get yourself some rosin solder flux (do NOT use plumbing flux). If you use an acid based soldering flux, you'll ruin your board.
              • ckramer
                • May 2021
                • 4
                • Inited states
                #67
                You have been tremendously helpful and patient. I'll certainly try what you have said and let you know if I'm successful.
                • thstuff
                  • Jan 2015
                  • 17
                  Fixed an E550i-B2 today with fractured Power Supply CN202 solder joints.
                  This failure may be due to a 3-4X difference in CTE (coefficient of thermal expansion) between the glass reinforced plastic chassis and PCBs clamped to it by 13 screws, resulting in high forces directly applied to CN202.
                  To remove the force on CN202 I decided to 'float' the LED Driver PCB as follows:
                  - Remove LED Driver PCB
                  - Under LED Driver PCB, trim off the plastic locating pin near upper left corner and both right edge mounting screw bosses flush with the chassis.
                  - Reinstall LED Driver PCB but do not install the two screws on left edge and replace the two right screws with a #6 screw thru PCB and metal ground tab secured with a nut.
                  The LED Driver PCB is now supported on the left by CN202 and right by the metal ground plate taped really well to the plastic chassis.
                  Will know if this helps in a few years
                  • ajshoe
                    vizio E60-E3 backlights, sound, no video
                    by ajshoe
                    Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                    Does this mean remove right side (from front of TV) tabs ?
                    Like a second opinion before possibly destroying set....
                    04-07-2023, 01:59 PM
                  • soeren
                    A2442 - No sound over internal speakers and no video playback
                    by soeren
                    I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
                    All happened after the battery ran out of power overall several days when I was on vacation.
                    I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
                    07-26-2024, 01:24 AM
                  • FrancescoV
                    Onkyo HT-R390 no sound output, video output ok
                    by FrancescoV
                    Good morning everyone,
                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                    The firmware reported is the following:
                    M:1.00/11107BLP
                    D:?.??/????????
                    O:1.00/11107AL
                    The DSP firmware given the question marks seems corrupt.
                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                    05-11-2025, 02:59 AM
                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                    09-12-2024, 02:00 PM
                  • JaquesPratt
                    Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                    by JaquesPratt
                    I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                    This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                    07-16-2024, 01:04 AM
