Please HELP Rca led50b45rq
  • mu2
    • Oct 2009
    • 217
    Re: Please HELP Rca led50b45rq
    Can you list the mainboard part number?
    I might have one in my parts bin that is functional.
    Mike
    • zblad
      • Jun 2013
      • 23
      Hey so I unhooked the ADJ wire from the plug and the tv works fine not sure how safe it is to have the wire unhooked though :s T.RSC8.78 is the mainboard number. The only weird thing is the volume seems really low and I am not sure why? Maybe that ADJ wire has something to do with that.
      • zblad
        • Jun 2013
        • 23
        let me clarify a little better basically I have everything hooked like it should be so I am not jumping power from the powerboard the power is coming from the mainboard and telling my lights to come. I unhooked the ADJ wire because its almost like its telling the mainboard to shutdown. Not sure if that helps at all.
          ADJ wire is the command signal to control how bright the backlights will be, so when you disconnected the backlights is probably be running at full level, nothing to do with sound.
          • zblad
            • Jun 2013
            • 23
            Alright thank you for clarifying this site is a life saver. What would you do leave the wire unhooked or order a new mainboard? I am assuming it is the mainboard.
              Similar problem with other RCA TV also:
              https://www.badcaps.net/forum/showth...&highlight=adj
              Cheaply made TV so more likely the LEDs will fail soon and also the main board.
                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                I am comparing them to a brand new one that I installed
                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                I going to let it run for several days before I remount back on the wall next to the...
                09-05-2024, 06:48 PM
              • Kingfreddie
                LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                by Kingfreddie
                Ok.. this is the story:
                Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                This is kinda how it looked, just that mine were at the bottom of the screen:
                09-11-2021, 01:57 AM
                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                09-12-2024, 02:30 PM
                HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                09-06-2024, 08:10 PM
