Please HELP Rca led50b45rq
+ More Options
Posts
  • zblad
    • Jun 2013
    • 23
    Hello all,
    I have been working on an Rca led50b45rq and am completely stumped. The issue is the tv turns on for a split second and the powers off. I have tested all the voltage and I have tried swapping out the power supply and mainboard. The issue seems like it would be the led strips but they all turn on just fine. If I plug the tv in I get a small red led hit power red led shuts off and then tv backlight come on for about 1 second and then tv shuts down. The red LED remains off. I unplug the tv plugs it back in and the red led is back on. Now here is the weird part if I unhook the led strips power and plug the tv in small red led comes on I hit the power button led goes off wait 5 seconds obviously cant see any screen because the leds are unhooked, I hit the power button and the red led comes back on like it shut down properly. Basically why does the tv seems to work fine with the leds unhooked but powers off if they are hooked up.
    Thank You,
    Zach
    Re: Please HELP Rca led50b45rq
    "The issue seems like it would be the led strips but they all turn on just fine" May I ask how you verify that?
    Pictures if the all the boards and the whole back side of the TV so we can see how all the boards are connected together?
    • zblad
      • Jun 2013
      • 23
      Here is a picture of all them on I will get one of all the boards in a few minutes.
        Ah, you already took the panel apart.
        • zblad
          • Jun 2013
          • 23
          Here are the boards
          If I unhook the left leds that are in series it doesn't change anything
          If I unhook the right leds that are in series it doesn't change anything
          If I unhook both at the same times the tv looks like it works fine as far as powering on and off.
          Its almost like the leds are either drawing too much or too little power because they all work. But for that to make sense that would mean both sides are messed up.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            I'm not 100% sure of this but considering that all the leds are on in your photo, they don't appear to be as blinding in brighness as in other photo's posted of the back panel leds being on. Just a thought.
              Yea, I wonder what DCV he is getting at the L+.
              Ref. to this thread:
              https://www.badcaps.net/forum/showth...Rca+led50b45rq
              • zblad
                • Jun 2013
                • 23
                I checked voltages about a month ago and if I remember right it spikes up and then fizzles down to like 30v and then drains down. That's why I thought it was the powerboard but I swapped that out and still did the same. Only thing that makes a difference is unhooking the led strips... I completely lost on what it is. Thought about hooking just one strip up to each side but will that be too much power to the strip and zap the leds?
                • zblad
                  • Jun 2013
                  • 23
                  So maybe we should take a step back when i got my powerboard it was used and the fuse was blown so i swapped fuses and the tv did the same thing. The voltages of both L+ and L- are similar. When I tried a different main board it wasn't exactly the same model number not sure how much that would matter because it did a similar thing if i remember right. All the LEDs work so i feel that can be eliminated so what board would it most likely be if you had to guess...
                  • zblad
                    • Jun 2013
                    • 23
                    im confused why L- has voltage isn't that ground? or what does the L- and L+ do?
                      L+ is the Anode side of the LED string which is fed by boosted Voltage from the boost converter circuit, the L- Cathode is the return side of the LED string which is connected to the PWM controlled power MOSFET and then through the current sensing resistor in which the Vdrops on the resistor is used for maintaining the constant current through the LED string.
                      • zblad
                        • Jun 2013
                        • 23
                        So the L+ voltage is what powers the LEDs... Is there anyway I could turn the LEDs on with a separate power supply if so how many volts would I need? Or is there anyway I can trick the tv from powering off? Or what board do you think is causing the issue?
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Have you checked Con4 to see that you have the Backlight ON signal from the main board. Can you force the backlights on using that pin connected to Vstby?
                          • zblad
                            • Jun 2013
                            • 23
                            How would I go about doing this just ground out my black prong on my voltage meter and put red on con4 im guessing?
                            How would I force it do I ground that pin out or ...
                            Thanks for the help
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Start with just checking the voltages on Con4
                              Con4
                              Pin 1 = GND
                              Pin2 = ADJ
                              Pin3 = BKL
                              With black lead on chassis measure the voltage on the 3 pins using your red lead.
                              • zblad
                                • Jun 2013
                                • 23
                                Alright I am going to do my best at describing this....
                                BLON - Stays at 0 hit power button and doesn't change until the LEDs flash then it gets 5v for a second and falls back down to 0sh.
                                ADJ - Stays at 0 hit power button and it goes to 5v and stays there until LEDs flash and then falls back down.
                                GND - Stays 0 the whole time.
                                If I unhook the little plastic connector with 3 wires I cant turn the tv on and off with no LEDs. But it atleast doesn't go into the protection mode or whatever you would call it...
                                • zblad
                                  • Jun 2013
                                  • 23
                                  I think I get what your saying just unplug both ribbons and run a jumper from vstby to con4 BLON and see if they stay on?
                                  • zblad
                                    • Jun 2013
                                    • 23
                                    OMG IT WORKED!!!! If I plug the tv in power it on and jump from VSTBY to the BLON they stay on just fine. So I don't know if its the powerboard or the mainboard at fault I would assume the mainboard.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      The mainboard should provide the voltage to BLON. So that is missing for some reason. Reconnect everthing and then check what voltage you have at BLON when you switch out of standby.
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        If you can force the backlights on and they appear to be OK then it looks as though it is a mainboard fault. Can you post a really sharp picture of the mainboard. It would be worth seeing if there are any voltage regulators on it that could be checked out.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • Kingfreddie
                                          LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                          by Kingfreddie
                                          Ok.. this is the story:
                                          Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                          This is kinda how it looked, just that mine were at the bottom of the screen:
                                          09-11-2021, 01:57 AM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
